HI,
My sony player is not playing this PAL DVD. I want to convert to NTSC DVD. I read guides but they all helping just the main movie conversion but I want convert all the PAL DVD to NTSC DVD. Is there anyway I can accomplish this?
Results 1 to 14 of 14
Ranjith
Have you read DJRumpy's guide?
www.videohelp.com/forum/viewtopic.php?t=221928 -
Yes I tried, even Nero Complain like "couldn't locate the files" when I burn, I ignore the the message and burn the dvd and played but it wasn't working.
Ranjith -
That patch method is nothing but VooDoo
You can either buy a player that will convert PAL to NTSC for very cheap or if you want to spend a little time (depends on the speed of your pc) converting it check here
https://www.videohelp.com/forum/viewtopic.php?t=261056 -
Hi
sorry but I checked but there is no proper guide that I can follow. DG pulldown is for files like AAA.m2v but I have a Full DVD ripped in hard drive.Ranjith -
Yes I want to spend as much as time converting this PAL DVD to NTSC (main movie, special features etc) and if that worked then I am willing to post that guide here so any one who lives in North America no need to suffer but simply can follow my guide!
Ranjith -
Hi,
The guide i posted is very easy if you just use the programs listed in order
I've already done a few that way and they came out great!!!!!! and really did'nt take much time, the most amount of time was a 1 hour & 20 minute video i did and it took about 1 1/2 to 2 hours to encode just the video with TMPGEnc Plus. I could list it all here but it already is on the thread i supplied.
It is a little more advanced but relatively straight forward. -
HI
I am following this thread
https://www.videohelp.com/forum/viewtopic.php?t=219852
seems good with lot's of info
I use CCE
ThanksRanjith -
The one i listed is newer with new methods so you don't have to change the audio to match the conversion of the video by leaving the video at the original 25fps of PAL but changing the resolution and then using DGPulldown, it's all there, and then you can remultiplex the audio & video back together in an authoring program and the audio will match the video because the video is actually still 25fps, the one you are looking at you have to mess with the audio also.
Like i said, i have tried this new way a few times now and it's easier, faster and looks as good as any way i have tried, and i have tried almost all off them
If you really want to make it easy dvdSanta , DIKO & maybe other's, are said to convert PAL video to NTSC video but most one button solutions never seemed to work real well for meor resulted in quality i liked, i like more control to be able to tweak 8)
Ok I tried and didn't work because of the audio and FInally I am going to go with your method
Thanks for that replyRanjith -
I seperate the Movie file using DVD Lab and now I have a ac3 file and mpv file. the " movie.mpv" file which is PAL I want to Resize the video to NTSC 720x480. How can I do this? Because I am going to use DGPulldown to convert 25fps to 29fps
Ranjith -
well i don't use & am not sure if you can open the mpv in TMPGEnc.
try and let me know
And read over the original thread i posted that FulciLives started and this one
https://www.videohelp.com/forum/viewtopic.php?t=263172
i talked a little about it but the way i do it, leaves out avisynth as i like to have a little more control and tweak setting in TMPGEnc when re-encoding the video and is a little more advanced as you really need to know what all the little settings are for
After ripping the .VOB's to my hard drive you can use TMPGEnc to get just the audio track from the vob, when i rip i set my ripper to one large file, then use dgmpgdec to get a .dv2 file to open in TMPGEnc and re-encode just the video.
but you can rip the usual way and have multiple vob's and get both the audio and d2v files, then just re-encode the video using the d2v file with TMPGEnc, making sure to keep the frame rate at 25fps but making the resolution 720X480 and the output as NTSC. if you are notn sure what all the settings do or are for in TMPGEnc.
You might want to really read over the original way, the link i posted to.
I think i might have to sit down and write a guide on how i did it
whats one more among the 1000's -
Thanks for that, I download the DVDstanta trial and in few hours I have a NTSC DVD. It converted the main movie and the quality was very identical to the original PAL DVD. I am very impressed and my entire problem solved. I was looking for a program like that in GOOGLE and couldn't find it until u mention it. Thanks AGAIN.
Ranjith
DVD PAL to NTSC or NTSC to PAL DVD Conversion
By Baldrick in forum DVD RippingReplies: 21Last Post: 12th Apr 2016, 17:30 -
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
