Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 9 of 9
  1. I am looking to get some inkjet printable DVD's for my Canon Pixma IP5000 which has a tray for printing directly on to the DVD itself. I have been looking at Verbatim and Ritek, but am wondering what people's experience is with these, or if any other is recommended. I am printing full colour labels, edge to edge, so need to be good quality. Any advice much appreciated. I am in the UK by the way. Thanks...
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I use Verbatim. 22mm hub. Great quality. Too be honest every DVD i have printed on has been great with this printer.
  3. Where did you buy them? Online?
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    can't remember but it would have been bigpockets.co.uk or cdr-media.co.uk
  5. Thanks.
    On the pic below, do you know if you can print in the white bit on the inner part of the disc? This is one of the only discs that I have seen with a separate white part here, as most are either just plain plastic on inner section, or covered with an entire label across the disc surface. Unless this picture is just misleading...
  6. Goto www.rima.com and look for DVD recordables that say they are inkjet printable (+r or -r as suits yourself) Taiyo Yuden is supposed to be good.
  7. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    http://www.cd-rmedia.co.uk/cgi-bin2/details.pl?id=vdvdrsppr8x
    or
    http://www.burn-media.co.uk/acatalog/Printable_Media.html
    What you want is full face media if you want to print to the hole. The Datawrite 8x Full Face Printable is good @ 5.25 inc VAT for 25
  8. Why are those Verbatim's at cd-rmedia.co.uk so much more expensive than all the others. Nearly 3 times as much!? Is it is the 'photo printable' feature? Are they worth it?
  9. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Not tried the photo ones mine are matt...
