Is it lossless? or does the camera compress it somehow first?
My Canopus died on me (maybe) and started using a pass through via my Canon. but would like to know if the pass-through is inherently worse or not.
THanks!!
Both I believe are DV25, so both are doing the same amount of compression. Neither is lossless.
The Canapus probably does offer more settings for internal extra filtering built in that might give you a percieved better video, but I don't know for sure.
I use my Sony passthrough for VHS conversions, and it is by far the best quality I can get compared to HuffyUV capture with Leadtek capture card or MPG2 direct capture with software or even hardware comression(PVR150) -
Thanks! I completely forgot about the DVCodec.
So, it's 25Mbs, 5:1 compression, 4:1:1... all I pictures.
Cool. appreciate the quick response to my stoopid question! -
Don't feel stupid, when you get into this stuff, there is so much information that sometimes even the basic things slip the mind, ha ha.
I know, I do it too,
Difference Between 1 pass & 2 pass encoding
By iqbal88 in forum Video ConversionReplies: 28Last Post: 29th Oct 2021, 06:19 -
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
1 pass and 2 pass bit rate query
By socrates in forum Blu-ray RippingReplies: 1Last Post: 26th Nov 2010, 16:18 -
Retrospectively check if One Pass or Two Pass Encoding was used?
By BenjaminBS in forum Video ConversionReplies: 4Last Post: 26th Nov 2009, 06:46
