  1. Banned
    Feb 2005
    I have an Asus Xtreme AX300 SE/T video card. (ATI technology)
    I have been unable to program the TV out function.
    I believe I have programmed it correctly, but cannot get any reception
    from the TV. My TV has a composite in jack. My card has a Svideo out
    port, and a 6" conversion cable, to convert from Svideo plug to a composite
    RCA plug. It came with the card.
    I have tried all the troubleshooting tips that came with the card software,
    have latest ATI drivers, etc.
    I don,t know if I am at fault, if the card is defective, or my TV is not
    compatible.
    Does anyone use one of these cards, that could give me some help??
  2. Have to ask since you didn't mention it- did you set up your tv to recieve correctly?
  3. Banned
    Feb 2005
    Yes I did.
    I only have two options. Video being one of them.
    I selected that setting, and it did,nt help
    I also went through resolution settings, etc.
    That is why I asked if anyone has one of my model cards, and have it
    functioning correctly.
    Thanks for your input.
    You are in breach of the forum rules and are being issued with a formal warning. Goodbye, Travlur.
    / Moderator Cobra
    (New identity of an old banned user)
