Size problem (Xvid to SVCD)
Hi, i'm having a problem controling the output size to fit one CDR.
No matter which videobitrate I use, I always get a bigger file than one CDR.
I need some experienced help please.
Thanks.
"Split in [2] chunks" in the Tools tab. And use "2 CDs" in the bitrate calculator.Originally Posted by Evochamp
According to the "How to" pages, you should try the KSVCD preset to hold upto ~60 minutes per disc.Originally Posted by Evochamp
SVCD, from what I've read, is not fixed to one specific bitrate so it seems you can push it to about 55 minutes of video on 1 CD if using 128 kb/s sound and NTSC film with pulldown. I'd suspect this might be more compatible than ksvcd, but don't quote me on that. It might also be possible to increase that amount a little by compromising on quality and lowering the bitrate below 1800.
https://www.videohelp.com/svcd
Unless there is some specific reason for using CD over DVD, like not having a DVD burner, Half-DVD (352x480) might also be an option. Using Half-DVD you can fit about 5 hours on 1 DVD at a quality comparable to that of SVCD.
Alph
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 17:05 -
Xvid bitrate and file size problem - Heeelp!
By Salinas in forum DVD RippingReplies: 0Last Post: 10th Mar 2010, 18:05 -
DVD to avi(Xvid) - size problem
By skipadipadoo in forum DVD RippingReplies: 4Last Post: 9th Mar 2009, 10:07 -
Xvid Encode by File Size Problem
By hech54 in forum Video ConversionReplies: 5Last Post: 1st Jul 2008, 12:45 -
Problem with bitrate and file size when encoding with XviD
By megakoolkid in forum Video ConversionReplies: 13Last Post: 25th Jun 2007, 18:12
