  1. I have downloaded a movie. In description it says its a CAM DIVX AVI, but still says AVI in properties.
    It is 240Mb long and I have downloaded the DIVX Codec 4.11 or thereabouts.
    I have tried to play it thru that prog but it does not engage with it.
    I have also tried through Windows Media Player 8 and Adobe Premiere 6, to which nothing but title of film appears at the bottom and length of film.
    I have also tried that DVD player program....
    There is no indication the file is corrupt, but how can I tell???
    I am running Windows XP on an Athlon 1.4Ghz
    Please advise me...
    Darren
    Aug 2001
    Västerås, Sweden
    are you sure you installed divx codec correctly?
    i think there are som file you should run after installing ..or was that the 3 alpha..
    readme should tell.
    Well, I am the slime from your video.
    Oozin' along on your livin'room floor.
