as title. I know since version "n" or above, ffmpegX support rm file. I drag the rm file, the Quick Preset(i tried different mencoder engines too) show up, then press Encode. It took 1 sec and finished. Of course, no file was converted. The process information is:
Encoding started on Thu Mar 24 16:44:24 PST 2005
MEncoder dev-CVS-050123-19:55-3.3 (C) 2000-2005 MPlayer Team
Mac OSX static build for ffmpegX
AltiVec found
CPU: PowerPC
success: format: 0 data: 0x0 - 0x5210d66
REAL file format detected.
Any suggestion will help. Thanks ahead.
PS. I'm G5 OSX 10.3.7, ffmpegX 0.09s(I also have the problem for ffmpegX to locate mpeg2enc everytime it startup).![]()
Results 1 to 11 of 11
Check on the page http://homepage.mac.com/major4/download.html whether you did install the real libraries. Also not all versions of rm are supported (rm9 and rm10 are supported). Check the same page for indications to find the correct version of mpeg2enc (which has to be 188524 bytes in size).
thanks major. the mpeg2enc problem is fixed. but i still have no luck to convert the rm file. here is the info of the rm file:
Stream:Source0.Stream0
Stream info
Codec:RealVideo10
Stream:Source0.Stream1
Stream info
Codec:64kbps - RealAudio (RealAudio G2)
does that mean anything to you? is that a version that can't be converted? what if i re-save the file as real10 version, will it help?
thanks.
Real10 should be converted. Try to open it in ffmpegX and tell me what the left-side LCD says about the file format.
Do you mean "Source format"? There is no file format shown up on the "From", "Video - no video" and "Audio - no audio". I can't get info from the "Info" button, can't "Play" the file(mplayer crashed all the time) or "Preview" the file.
Did you install real libraries as indicated in http://homepage.mac.com/major4/download.html and which version did you install? In case of doubt always install the "stable build" of real libraries linked in that page.
You should try the "stable build" mentioned in that page. The link is http://prdownloads.sourceforge.net/mplayerosx/reallib.zip?download
Thanks major, finally i got the right reallib file, and it show up the info of the rm file on the left LCD. Now the only problem is, the rm file didn't converted yet, it only took 1 sec to finish the job and nothing came out. Is there any setting i need to be aware of(now i used the quick preset)?
thx.
Click the blue "i" icon in the progress window with the full process output (including possible error messages) and email it to me to major4@mac.com
How can I convert a .mov file that has been tampered with?
By ktconverter in forum Video ConversionReplies: 5Last Post: 30th Jul 2010, 19:38 -
mencoder wont convert the complete file, mov to avi|mov
By bjornieB in forum Video ConversionReplies: 2Last Post: 19th Nov 2009, 07:42 -
convert MOV file?
By AlanHK in forum Video ConversionReplies: 3Last Post: 18th Sep 2008, 06:27 -
Convert WEIRD .MOV file....What program should I use?
By RushMaster in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2008, 17:14 -
Best way to convert .mov(QT) file to an .avi file...... is?
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 3rd Sep 2007, 21:05
