Results 1 to 14 of 14
  1. Where can I download azid? I have been looking everywhere and all I find is it it codec packs. Can some give me a link, please?!!!!!
  2. What is Azid?
  3. It is an AC3 decoder that I would like to use with BeSweet.
    It is also known as a codec.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    it comes with it - unless you mean azidts
  5. Heres the file. azid.zip
  6. in case you have not been able to donload from canadatek. Here is another link
    http://www.digital-digest.com/dvd/downloads/azid.html
    When I was born I was so shocked that I could'nt speak for 18 months.
  7. Thanks All!!!
    I followed the links and they worked perfectly!!
    Thanks again!!!!!!
  8. What is it the application used for?
    Ghost Notes
    Dec 2004
    Australia
    AC3 decoding/downmixing.
  10. I downloaded the zip file but it did not have the dll. does anyone know where the latest version (1.9) of the azid dll is? it would help alot if i could find it.
  11. The zip I gave you does have it.
    azid.dll
  12. Thanks alot man!!! how are you so fast. and where did you find the azid stuff?
  13. Член BJ_M's Avatar
    Jul 2002
    Canada
    on the internet -- google works good
  14. Член BJ_M's Avatar
    Jul 2002
    Canada
    i thought it still comes with besweet anyway ....
    its been so long i can not remember
