can i use the mpg4 codec? will that produce an mp4 file?
VirtualDubMod can only output avi, ogm or mkv. As a general rule it isn't upto the codec to choose the output format, with the exceptions being some VfW mpeg encoders, the old DivX 4.x which could actually output mp4's, not spec compliant I don't think though and ffdshow which doesn't yet support mp4.
You would have to output an avi containing MPEG4 video and then remux to mp4 via mp4creator, mp4box, the 3ivX muxer, etc. There are also some GUI's for mp4box, mp4creator and related.
Think I read that PSP was SP only so QuicktimePro should be able to do a pass through to mp4.
PSP Test Clip: Need someone with a PSP to test for me!
By FulciLives in forum Portable VideoReplies: 5Last Post: 17th Feb 2009, 21:42 -
I got a PSP.
By Xylob the Destroyer in forum Off topicReplies: 4Last Post: 10th Feb 2009, 23:10 -
My XviD4PSP PSP video conversions are not supported on PSP
By godfist314 in forum Portable VideoReplies: 3Last Post: 18th Aug 2008, 11:59 -
Downgrade your PSP to version 1.5 using your PSP battery
By chrise in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 09:27 -
Nero 8 Recode to PSP - No Title on PSP?
By sonicm in forum Video ConversionReplies: 1Last Post: 6th Dec 2007, 15:13
