Hello I have been seaching for an answre on the forums all morning yet to no avail. I have tried to make 3 DVD's from 3 different bin files and in every DVD player I play them in the video jerks for about a minute and then it will paly fine for about 1 min. then go back to jerky motion. I have the RC 6 version and was wondering if I could revieve a little assistance with this problem. Also I am using the quick DVd option.
Results 1 to 21 of 21
What dvd player exhibits this? What does the dvd play like on the PC?
I have tried this on about 8 different DVD players and have not tried it on pc yet, I can as soon as I get off work tonight yet im sure this is not normal and just to ask a question and I truly mean nothing by this just inquiring why is it often asked will the disks play on the pc
Ok I attempted to play the file on the pc and there were lines in the pic and like 3 shadows of the same movie over lapping
I aggres this is not normal - especially on the PC. "Does it play on the PC?" is asked to eliminate the fact that the DVD player might be having problems. If the PC does too it usually means the dvd has been authored incorrectly. It helps me to narrow things down - thats all.
Can you email me your log file.
Thanks.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Excuse me for the ignorance but what by chance is a log file and how exactly do I access it.
There is a log generated for each SVCD2DVD run. It is located in the logs folder under the folder where SVCD2DVD is installed. Each log is label with the date, svcd2dvdlog-yyyymmddhhmmss.txt e.g: svcd2dvdlog-20050324205008.txt
Thanks alot thats new to me im sure its all user error
im at work now but if I can get a break here at lunch i'll post it asap and thanks again for the response and the product.
Got it thanks. I will take a look at it.
ChrisSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Not yet.
I just tried again same thing happens is it possible im doing something wrong the bin images are extracted i then select quick dvd yet it always resorts back to the jerky picture motion please can someone help
I am looking into it. Doing it again obviuosly will not resolve the issue until i have found the issue and resolved it.
BTW: how did it play on the PC - you never said.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Might have missed it I patiently await a response the reason I tried it agan was to see if perhaps there was something that I had done that was wrong and so not to waste anyone's time (was just giving it another shot I guess)Originally Posted by tgreen300
Yes. Sorry i did miss that. What software are you using to view the DVD on the PC
I'm still looking into it.
Could you send me a small sample of the original mpg to ftp://BetaTester:badger@ftp.svcd2dvdmpg.com:7676
(create yourself a folder)
You can use makesample: should be straight forward to use. See if you can get a sample which replicates the problem on the PC (WInDVD)
If your VIDEO_TS shows the issue can you upload that too along with the log?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
worked for me...
https://www.videohelp.com/forum/viewtopic.php?t=262485&highlight= -
Dont have the original file any more deleted after I went ahead and did it the old fashioned way yet the jerkyness happened on all files I attempted to use -As far as the burner I use is a NEC 3500 and I use Taiyo Yuden discs no other problems whe I did the old fashioned way.
Jerky playback
By hi2shy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 30th Nov 2010, 17:44 -
Jerky Playback
By electrowiz in forum Video ConversionReplies: 1Last Post: 25th Aug 2010, 17:16 -
jerky playback
By VOYAGER2009 in forum Video ConversionReplies: 19Last Post: 22nd Feb 2010, 06:27 -
Jerky playback on TV from PC using TV Out
By digidude in forum Software PlayingReplies: 0Last Post: 30th Dec 2008, 18:26 -
Jerky playback of AVI on TV
By kostnkost in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jan 2008, 17:32
