Q. I`m a registered new user of SVCD 1.5. Should I use 2.0 RC6 instead?
Q. Does RC6 install to 1.5 folder or should I use it`s own folder?
I know nothing about svcd files except they play on the cpr.
Problem: I am trying to put several svcd files on a dvd with a menu.
One of the files causes a problem every time I run the set.
Error is that File_has NAV packs and the program drops that VTS.
(Get no VIDEO_TS set for it.)
The other files process ok, and came from the same source.
I`ve retried this several times; same prob.
I ran all of the original mpg files thru the "Fix Mpeg feature and all were processed ok.
That solved some of the comments in the log that I had gotten before.
Idea on how to correct this navpak problem?
Another problem next msg.
V2 and v1.5 can coexist - they reside in different folders. Try the same files with v2 RC7 and if you get an issue - email or post your log file.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31 -
SVCD / MPEG2 - bad packet stops file.
By Steve Walsh in forum Authoring (VCD/SVCD)Replies: 5Last Post: 9th Jul 2007, 13:03
