I just installed this card and I'm having some problems with the sound ... big suprise. DVD's, mp3's, and CD's all play fine ... no problems ... TV ... no sound. I've bumped up the volume with no luck.
The card came with an audio cable ... one end I have hooked into the Aux Audio In connex on my SoundBlaster Live 24bit card, the other is hooked into the ASUS card in the only place it can be connected ... a 4 pin connector on the card. I'm stumped. I have an extra 4 pin connector on the audio cable ... should it be connected on the motherboard somewhere?
Any help will be appreciated.
Thanks,
Lu Ann Johnson
Try settingt your capture software to use the AUX on the SB as audio source.
Sometimes there are different settings for different portions. For example, capping from S-Vid has one section for settings, capping from tuner will have another.Cheers, Jim
My DVDLab Guides -
That's exactly what it was! I had to go into the SB audio setups ... Control Panel >> Sounds and Audio Devices >> Volume Tab >> Advanced >> Properties >> un-check the aux-in option.
I can't believe I overlooked this!
Now ... what the heck is the usb device that came with the card??
laj
No dvb-s signal from satellite and Asus My cinema es3-110 card
By mammo1789 in forum DVB / IPTVReplies: 4Last Post: 28th Dec 2011, 18:13 -
Using ASUS ENGTX460 DirectCU Graphics Card To Convert .mts Files?
By JohnnyGalaga in forum Video ConversionReplies: 30Last Post: 15th Jan 2011, 23:22 -
Ts Muxer Blues
By romanticwarrior in forum Authoring (Blu-ray)Replies: 3Last Post: 2nd Dec 2010, 09:17 -
XVID to other formats audio blues!!!
By PunkMaister in forum Video ConversionReplies: 6Last Post: 29th Aug 2008, 17:06 -
Asus My Cinema P7131 Hybrid Capture Card - No Audio or Digital Reception
By Duchess in forum LinuxReplies: 10Last Post: 5th Jul 2007, 07:55
