some movies i convert from either .AVI or .MPEG are out of sync how do i fix the the .VOB files![]()
Results 1 to 11 of 11
You might try this: Before capturing/"converting," de-frag your hard drive.Originally Posted by starcraft_20002000
(If this doesn't help, hopefully someone else will have some advice that will work for you.)
Good luck! -
What are you converting the AVI's with..what encoder??
What did you use to Author the DVD? -
That just might been the problem,Have you tried anyother way? try to use a stand alone encoder then Author the Mp2 to DVD.
I would encode to Mpeg2 with TMPgenc or MainConcept MPEG Encoder and Author with Ulead Movie Factory ,TDA,Ulead DVD Workshop,DVD Architect. You Pick take alook at the trials and see what you Like.
I have similar problem with dvdsanta. I am converting some music videos from different format (eg wmv, avi, m2v, mpg). Some output have a/v sync problem. The audio seems to be sped up, thus play beyond video. Only on some files tho. I checked the original file and it plays find. Any idea how to fix this?
decrypted, converted .vob to .mpg but have no menus
By chgoguy in forum Video ConversionReplies: 6Last Post: 8th Aug 2009, 17:03 -
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 09:59 -
alltoMKV converted MKV file sound out of sync.
By necrobutcher in forum Video ConversionReplies: 1Last Post: 10th Jun 2008, 18:25 -
Fixing SYNC on affected converted .VOB's....
By snadge in forum Video ConversionReplies: 4Last Post: 16th Jan 2008, 17:54 -
Audio becomes out of sync when converted (transcoded?) from .vob files
By Neptuna_Fish in forum Newbie / General discussionsReplies: 12Last Post: 21st Aug 2007, 20:39
