i just read a bunch of how to's on here and i am confused about the easiest way to convet svcd to dvd. i have two halfs i want on one dvd, simple no menu just pop it in and Boom. i can fool around with menus after the disc is made. i just want to convert it with the least amount of software and free of course..........
Results 1 to 11 of 11
The easiest way is to just author as-is.
No "conversion" needed.
DVDLab.
Load both mpg's.
Change the Firstplay link to go to the first movie, bypassing the ROOT VTS.
Right click in Projects, add movie.
Put the second half in there.
Link movie 1 to movie 2.
Open Menu 1, and on the MAP tab, set timeout to A/V.
Compile, burn.Cheers, Jim
My DVDLab Guides -
use VCDGear to rip your .mpg files
drop them into TMPGEnc DVD Author
that's the simplest method I can think of (assuming you have those programs)
VCDGear is FREE!
TMPGEnc is NOT.........
i don't know if this will work with other authoring programs, as I have only used TMPGEnc's authoring"To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
"Megalomaniacal, and harder than the rest!" -
I don't think SVCD resolution will work on a dvd, i know vcd will drop right into TMPGEnc DVD Author but.....
Originally Posted by BaldrickOriginally Posted by lordsmurf -
thanks for the tips guys but all those apps cost $$$ i was looking for a easy cheap way. i don't mind having to do a complete re-encode
If you have Nerovision Express, it will convert, let you make menus and stuff, as well as burn.
The free tmpgenc will let you merge the two as one file, in mpeg tools.
ReJig will author the mpg to dvd.
VSO divx to dvd will take both files and join them and convert to dvd. (it's free, and probably the easiest)
It SAYS it will only do one file at a time, but if you open the box to select your file, hilight the SECOND one, then hold down the ALT key, and select the FIRST one, it will join and convert.Cheers, Jim
My DVDLab Guides -
i tried VSO and i had it select the two files(yes, i'm sure it selected both) and it said 60 min. to complete well after 30 min it stopped, i was like ok? so i try it again nd it seemed to do both files into one. now what i am left with is a vob file to be burned, so i pop it in nero and drag the vob into the video folder and burn, nero is squaking about it not compliant so i burn anyways and now lets say i have to get a screw driver and butter knife to get the disc out my cheap player. Was there something in the conversion that was not donw right? or is this what is does? make a 1/2 compliant dvd that %50 might work? on the options i used 16:9 and force ntsc.
the easiest way is Ulead. it's about 50$ and will convert, add menues and more in a couple of steps.
don't tkink there is any free stuff to do this.
AND you have to encode it again, diferent specs for dvd, if you want to make sure it works an all dvd players. -
If this is JUST for you, you can certainly TRY the SVCD-DVD approach, it's quicker and "relatively" lossless.
However, if it's for you and then maybe to use at your in-laws place or something, then you need to resize, resample, etc. -
gurm...whee about in MA are you?? i'll just come over and you can show the process. my friend talked me into getting dvdlab (i like what it can do for creating dvd's), is this possible to do the convert with dvdlad pro? what specs should this be converted with 16:9 and ntsc 29fps? all i want to do is put the svcd disc in, copy the aqs01(whatever) to the HD, convert both parts as one for that mofo, and burn as dvd. VSO seems to work but it was not compliant.
what is the simplest way to convert DTS to st-2.0?
By marklittlevai in forum Video ConversionReplies: 0Last Post: 22nd Oct 2011, 15:57 -
Simplest way to convert 1080p h264 mkv to 720p mkv?
By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 10:16 -
Simplest program to convert AVCHD to DVD
By Wam7 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 25th Mar 2010, 12:29 -
Simplest way to convert home VHS movies to DVD using VirtualDub?
By Pickngrin in forum Capturing and VCRReplies: 11Last Post: 21st Aug 2008, 08:32 -
Simplest way to convert and join avi's with different audio streams??
By Lolipop Jones in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2008, 11:25
