  1. Hello all I'm trying to make a backup of a DVD I have. I use DVD decrypter to get the vob files (I use the option of getting the main files only). I then go to the option of makeing a DVD using Nero express. Everytime I attempt to burn the DVD I get a message saying "DVD compliance test failed". Can anyone help me out? Thank You
  2. Are you using 5.5 with XP?
    I used to get this a similar problem. This way seemed to work...
    Open Nero as if you are going to make a DVD Data disc.
    Create two folders on the DVD: AUDIO_TS and VIDEO_TS.
    Put all of the Vob and Bup and IFO files in to the VIDEO_TS folder and burn.
    Hope that this works for you.
    Cole
  3. I'm a Super Moderator johns0's Avatar
    canada
    If you extract just the main vob files then you will be missing the bup and ifo files needed,best to get all the files.
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes - this is the problem -
    you need all the files
