I've tried a half dozen programs that normally work perfectly!
TMPGenc Plus 2.5
Broilsoft ASF Converter
ReJig
VDub
VDub Mod
XVideo too
None of them work they all say that there is some form of error when I go to recode them. The error messages differ. The VDubs said something about Microsuck owning the rights to ASF format and it wont process it.
The others said random things, some just froze. What else could I try? I can't even rip audio from the file using GoldWave.
I just did this one worked the best so far but still not working lolOriginally Posted by canadateck
I get this message:
Opening C:\ASF_Live.wmv
Header Obj ID OK
Data Obj ID OK
located: File property Obj
located: Audio Stream Obj, Stream #1
located: Video Stream Obj, Stream #2
Number of Chunks: 11635
Pass 1, Analyzing...
Found 11635 Chunks
Pass 2, Converting...
Chunks Discarded:0
Chunks Converted:11635
Frame rate set to:7.19424
Error: No video frame found on this stream: #2
File Closed.
I try to open it and nada. :\ -
And if so how can I get them to covert anyway? The person who made them isn't the brightest bulb on the marque.. he thinks he hit copy protect when he captured them... >
No I haven't tried that. I just assumed if Plus didn't work Xpress wouldn't either. :\Originally Posted by roma_turok
I will try that tho! Thanks
ASF problem playing audio
By Neomorpheus in forum Software PlayingReplies: 2Last Post: 14th May 2011, 02:56 -
converting asf to avi problem
By konig in forum Video ConversionReplies: 1Last Post: 6th Mar 2008, 15:37 -
Conversion from asf files to avi or mpeg
By Jescal in forum Video ConversionReplies: 1Last Post: 23rd Jan 2008, 16:37 -
Problem with recovered .asf...
By mksmri in forum Newbie / General discussionsReplies: 4Last Post: 21st Sep 2007, 11:57 -
Convert AVI to MPEG-4 (asf) for DVD player
By digitalife in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2007, 11:49
