i have 2 burners installed on my machine! one is a sony dvd + the other a nec both x8 speed.
Now first thing is my nec when i put in any dvd disk it takes ages to read it,and keeps spinning around and soesnt do anythink IS THIS BROKE.
Second question === now i ahve a sony dvd writer x 8 speed! burns dvds o.k but when it comes to playin them in my stand alone dvd player they dont always work,nec one burnt disks and they all worked 100%.
is there an option on my drive or is it set up wrong or i heard sumthink about the volume having to be in capitals!!! sorrry im think guys!! hope u can help!
ste![]()
You NEC player probably needs cleaning. Just a small chunk of dust on the laser lens can cause problems. Try some 'canned air' first, then a non-abrasive cleaning disc. If that doesn't work, try denatured alcohol and a cleaning swab, because you have nothing to loose at that point. Keep the swab dampened, not dripping to keep from washing off lubricant on the laser slide.
As far as your new burner, problems are usually first the media, (Try some different brands. Not all burners are compatible with all brands) make sure your DVD creation method is correct. If you are using Shrink to backup, this shouldn't be a problem. You might have to further describe your method. Are you making them from scratch? What software are you using? + or - media?
As far as the DVD drive setup, if it works at all, probably OK. More likely a software issue or media. -
Probably just dusty; how long is ages? Under 30 sec. is no big deal.Originally Posted by dj macca
Different drive work best with different media, get the recommended media list for both your drives and use media that's compatible for both.[/quote]Second question === now i ahve a sony dvd writer x 8 speed! burns dvds o.k but when it comes to playin them in my stand alone dvd player they dont always work,nec one burnt disks and they all worked 100%.
ste :shock: -
[/quote]Originally Posted by nic2k4
how do u suggest cleaning it then plz -
thanks for replyin so fastOriginally Posted by redwudz
well sumtimes im burning .img files or dvd copy 2 dvd copy! my nec burnt everythink u see thats why i got one cos the sony wasnt doin it! im usin the NEW DATAWRITE TITANIUM DVDRS X8 -R
As we all know titanium is one of the most stable and strongest metals obtainable in the world today. Its strength and reliability is world renowned, even used by NASA on the Space Shuttle.
This latest disc from Datawrite has been codenamed "Titanium", and utilises the rock solid Mitsubishi dye normally found in very high-end discs.
From the tough titanium sandblast finish to the highest grade polycarbonate plastic (less than 0.00001% defect), everything about this disc is bombproof and follows on from Datawrite's ability for making very high quality discs at very affordable prices.
The Mitsubishi dye used on this disc is at the forefront of dye technology in the world today. It is 100% rock-solid in terms of compatibility and playback and is a whole generation ahead of any other disc in the market.
Datawrite Titanium will set the standard for all discs to follow. -
The media could be too new for your NEC burner.
Read this: http://club.cdfreaks.com/showthread.php?t=120934#features-slower
You may want to try a firmware upgrade:
http://club.cdfreaks.com/showthread.php?t=122096
Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybe
By Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 18:02 -
Sony BDP-S350 problem with DVDR.
By blackhawk465 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 1st Aug 2009, 15:57 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 07:16 -
Sony DVD burner to youtube help
By short5 in forum Newbie / General discussionsReplies: 6Last Post: 16th Aug 2008, 15:33 -
LightScribe Media with Sony Burner.
By dragonsbb16 in forum MediaReplies: 11Last Post: 14th Dec 2007, 21:44
