  1. I have mulitple DVD music videos.I want to pick and choose certain songs from each DVD and put them on one.I used DVD Decrpt and I noticed VOB? files.Do I need to convert these files into another format?Could someone please send me to the right guide to use.Any help would be greatly appreciated.thank you
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    You will need to rip all your dvds to mpeg or avi. Then edit the files to get the parts that you want. Then you will need to reauthor.
    The rip guides should be in the dvd backup section.
    Google is your Friend
  3. Member p_l's Avatar
    Montreal, Canada
    Rip the DVDs to your hard drive as images (ISOs). Use DVD Shrink in Re-author mode to open the ISOs one after another (File | Open disc image) and drag the videos you want from the right pane to the left pane.
