  1. Hello. I would like to know if anyone here has this LCD monitor (or knows of a review of it).
    The specs seem good, and it has a DVI connection, but I'd like to hear from someone that has seen how good the monitor is (mainly because of the fake specs used by manufacturers nowdays) before buying it.
    Any help really appreciated.
  2. Member Prot's Avatar
    Dec 2003
    Oregon
    I have the VP171b. It has 2 analog and 1 digital input. I'm using the digital input with the 1280x1024 resolution. I like this monitor.
    May not be the best out there, but it definately suits my needs.
    TANSTAAFL
  3. Thank you!!
    Can I ask you how good is the OSD of that model?
    Have you seen the vx715? I might buy that one instead.
  4. Member Prot's Avatar
    Dec 2003
    Oregon
    OSD is fine. Haven't seen the vx715.
    TANSTAAFL
  5. OK, thank you. I e-mailed viewsonic and said that the vx715 had a 25 ms response time, so I think I'll buy the VG710.
    Thank you.
