Hi, a bit of a problem here,
I have 2 divx's which i joined using VirtualDubMod. I then use DVD2SVCD with the D2SRoba plug in to encode them to DVD ( It uses CCE 2.5 ). But the result files are only half the length of the movie - MP2's, mpegs, video TS folders etc are all only half the size of the joined movie !!!!
The original files are both the same audio - video - type....
I've used this before and had no problems.... This is the guide that i use most often.
http://www.dvdrbase.com/showthread.php?t=25572
Is there a problem with joined files and CCE ?
Thanks in advance for any help
Yes. It looks like the join has a problem. I would frameserve out of virtualdubmod instead of saving the file as Divx.
Read my blog here.
For further reference,
It seemed that using VirtualDub and not virtualdubmod and making sure that i selected - convert audio butrate to 384 did the trick.
Gotsent Sound Problem! 1st Half 2-Channel 2nd Half 5.1?!?
By Jerec in forum Video ConversionReplies: 1Last Post: 7th Aug 2008, 14:16 -
How Do I Split screen Half Rolling Credits-Half Video in Vegas
By Ray & Paula in forum EditingReplies: 1Last Post: 7th Apr 2008, 09:35 -
CCE mpv files imported into NeroVision are half as long???
By binister in forum Authoring (DVD)Replies: 7Last Post: 26th Feb 2008, 16:04 -
352x480 Half D1 Mpeg2 to Divx - How do I keep proper aspect ratio (40:33)?
By stizz in forum MacReplies: 16Last Post: 8th Feb 2008, 02:24 -
Uploaded video cut in half only top half shows
By MimseyTove in forum MacReplies: 1Last Post: 1st Jul 2007, 11:55
