  1. It never happened before.
    After "Create IFOs" for VOB files with director comments and multi-angle shots, the program " VTS_01_0" can not be opened for processing with "Nicht genugend Speichter" warning.
    I never did reset my system to German language. Where does this come from, and what does it mean? If it is a problem, how do I by-pass it?
    Gratefully Yours,
    JH
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Either it didn't find something (gefunden) or it couldnt save something?
    Two out of the three words are spelled incorrectly.
  3. Not enough memory. Could be the memory or HD space.
    Nicht genügend Speicher.
  4. Am transcribing exactly what the warning says except "ue" for "u"!
    As for the memory, am having 512MD physical RAM and at least 20 GB remain on HD. The folder to be processed is less than 7GB!
    Had even larger size folder and never shows warning, not to mention appeared in Germany (?) That's why I assume it's probably due to multi-angle with director and performers' comments?!
    IFOCreated files have no problem loading into PowerDVD. So it's not possible there are nothing for "VOBExtra" to process. As you may or may not know, for DVDShrink processing, the folder has to go through "VOBExtra" processing.
    Regards,
    JH
