    Jun 2004
    Toronto, Canada
    What is the best software to scan discs after they are burned? I just downloaded Kprobe is that the best? looking for most user friendly one that is easy to read.
    I use nero cd dvd speed, under Extra->Scandisc and select file and surface test.
  3. Aging Slowly Bodyslide's Avatar
    Feb 2002
    A Different Timeline
    Nero CD DVD Speed and DVDInfopro are what alot of folks use. I primarily use the Nero Tool.
    Jun 2004
    Toronto, Canada
    I have nero 6 is that included in that? Anyone have others
  5. Member Fandim's Avatar
    Jun 2004
    Reno, NV
    I like DVDInfo Pro...it just seems more apt to show even small spikes than Nero CD Speed does... I.E. I might have a couple small dips on my DVDInfo pro graph, but on CD Speed it's just the same old smooth line..
    :star: :star: :star: :star:
    Archived DVD Scans
    Nero V ImgTools V Decrypter
