Hi.
I have an MP2 file (from a DVB-S recording) with changing private flags inside the header of the same file. Since my DVD authoring software doesn't like this, I need to set every private flag to 0 or 1 (doesn't matter).
1. Is there any tool which permits to change the private flag through the complete file and recalculate the CRC?
2. Is there a tool which allows to analyse the MP2 file and view the flags used?
Many thanks.
pvstrumento "corrects" audio flags
I always - re-encode the audio for "just in case"La Linea by Osvaldo Cavandoli
... whithout reencoding?Originally Posted by SatStorm
... which generates quality loss. This would be the last resort for me.Originally Posted by SatStorm
Thanks for the answer. -
Yes, without re-encoding
Quality loss? Most DVB channels are already crap! Some times, even filtering is needed...
If you manage to detect an audio quality loss of 192kb/s mp2 > wav > 192kb/s convertion, then you sure have a hi-end audio system (amplifier / speakers)La Linea by Osvaldo Cavandoli
Could you please tell me in detail how you instruct PVAStrumento to correct the audio stream. I only found "'Beautify' MPEG1 L2 audio". But this function didn't to the job.Originally Posted by SatStorm
Thanks. -
It seems that it doesn't do the trick for you then. You need another software
I'm not aware of anyLa Linea by Osvaldo Cavandoli
The "Beautify ..." function apparently only touches the Copyright flag.Originally Posted by SatStorm
IE 8 - private browsing
By jyeh74 in forum ComputerReplies: 6Last Post: 4th Dec 2010, 07:34 -
How do I make a Blu Ray disk from an MP4 or MP2 file?
By True Colors in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2010, 05:26 -
Out of nowhere file size of video reset to 0kb
By MightyKing in forum Newbie / General discussionsReplies: 1Last Post: 13th Nov 2008, 17:49 -
Convert mp2 file in TMPGenc
By sdlehman in forum Video ConversionReplies: 1Last Post: 17th Mar 2008, 17:53 -
how to add the correct aspect ratio flag in an avi file?
By graysky in forum DVD RippingReplies: 15Last Post: 23rd Nov 2007, 05:23
