Hello!.. i cant get any paint on my television screen (only black and white), when i have linked it to my computer!. I have always haved paint before, cant understand what the problem is now. (grafikcard: Gforce 4 4600TI, if that can help).
I am pretty sure, that the cable+grafikcard is correct.
I have changed to PAL, thats what we use i sweden (a haved tried NTSC to but i dosent help). As i said before! : I have never had any problems with this, but i havent used nveiw in a while now so.... cant rember what i had attitude before.
Thx!
/Eriksson
well whats changed since last time it was working? new installs? or is everything the same?
the black and white thing really sounds like pal issue. you might wanna check deeper in the settings -
Ok! the problem is i cant look any deeper into the settning... i am not very good with computers.
I may have reinstalled windows.. i cant remeber!
( as i said was it a long time ago i used it)
Yeah, i also trough that it was a PAL problem.. but i dosent make any diffrents if a choose PAL...
So im despert for help, becose i cant see movies on the TV
/Eriksson -
Allright! i maybe now what i can be... i have heard that i haft to change
S-video to Composite
or something like that!
Does someone know where i can find that on a Geforce 4 4600TI ???/Eriksson
want to create a boxset plz
By Lugs in forum EditingReplies: 5Last Post: 15th Nov 2011, 20:23 -
Two simple questions, plz help!
By UnD3R0aTh in forum DVD RippingReplies: 40Last Post: 4th Mar 2010, 11:47 -
help with megui error plz
By runLoganrun in forum Blu-ray RippingReplies: 1Last Post: 17th Feb 2010, 22:43 -
Help PLZ! subtitle problem.
By Ajimal in forum Newbie / General discussionsReplies: 2Last Post: 15th Feb 2010, 23:25 -
plz help
By sajjad223 in forum Video Streaming DownloadingReplies: 1Last Post: 4th May 2008, 11:12
