Are there any free utils that will pull the audio off of a DVD
and convert it to MP3?
I wanted to try this w/one of my concert DVDs, but never heard of
anyone doing this yet....?
Thanks!
Did you consider doing a search?
DVD to MP3They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Um.. yeah. I did. Nice of you to ask.Originally Posted by drjtech
Most of the things I was finding were not free, and thus my
question about finding out if any of the products were free.
Maybe I should have rephrased the question, to a "which FREE product
would you reccommend for me to use for this...."
I probably would have gotten the same response instead of a friendly
reply. DO A SEARCH... Keep in mind that everyone is not familliar
with this board or as web-savvy as you and will need some help finding things from time to time.
But, anyways thank you for the links. I'll do some more hunting.... -
Thanks.. I'm downloading right now and will check it out!Originally Posted by Abond
Rip your DVD to one large VOB with DVDDecrypter - its free. So you dont have to juggle around with many VOBs. Or use the stream processing option to demux the audio.
Otherwise use BeSweet to extract audio from VOB files. Make sure you have vobinput.dll file.When I was born I was so shocked that I could'nt speak for 18 months. -
Belight is another Gui for Besweet.
If the DVD is a KaraOK or music video form then you may have to take time to cut them out. Can think of using MP3direct cut.
Commericial DVD audio rippers will save you the trouble.
How to rip dvd audio to mp3 or wav files?
By babypotato in forum DVD RippingReplies: 12Last Post: 17th Jul 2011, 04:22 -
WMP cannot rip CD to mp3
By kschwi in forum AudioReplies: 7Last Post: 16th Jul 2011, 12:11 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
Whats the best tool to rip DVD and keep AR & have VBR MP3?
By incrediblej in forum DVD RippingReplies: 53Last Post: 19th Dec 2007, 19:00
