anyone ever hear of this...have been tryin to author a dvd for my son and every program i use crashes after it starts ..about 2 or 3 % into it....have been using dvd santa Ulead movie factory and arcsoft software ...also when i use dvd shrink also it crashes.....have re-installed all programs and still the same...any ideas?
When you say 'crash' do you mean just the programs quit or the computer quits? If it's the computer, does it also quit when you encode or do some other CPU intensive task?
The reason I'm asking is to isolate the problem to either hardware (Memory failure or CPU overheat are two main possibilities) or software.
Software crashes with more than one authoring program is more likely a bad encode or improper encode that the authoring program chokes on. -
what i mean by crashes is the program just shuts down ...it used to give me the BSD instead ..made a couple of changes in the BIOS and now the programs just shut down....as for the source files....they were VCD's that i used iso buster to extract the mpeg files ...the mpegs seem fine also when i try backing up some dvd's with dvd shrink it does the same thing
DVD authoring programs - suggestions?
By jakewoodblues in forum Authoring (DVD)Replies: 3Last Post: 22nd Apr 2010, 13:53 -
Recommended DVD authoring programs...
By mjl1297 in forum Newbie / General discussionsReplies: 23Last Post: 18th Feb 2010, 21:14 -
MP4 Causing Programs to Crash
By HamishT in forum Video ConversionReplies: 1Last Post: 28th Feb 2009, 02:56 -
Programs crash because of broken codecs
By Stiff in forum Software PlayingReplies: 4Last Post: 26th Jan 2009, 15:22 -
How do I identify faults in MPEG files? Authoring programs crash...
By semmel in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2008, 22:28
