my speakers go into my dvd player....can I plug into a new dvd player into my old one ???
wils
Why are you trying to mate two DVD players
Pl explain properly what you have, what have you tried and what you want to finally achieve.When I was born I was so shocked that I could'nt speak for 18 months. -
As I understand he has speakers connected to one DVD player. He want to connect another DVD player to the first one in order to use the speakers. I think it will not work. Simply connect the speakers to the second (if you want it to use 5.1 sound and the other player doesn't support it well, no way I think, but I can be wrong also
Just how are only speakers connected to a dvd player?
If you are running through a receiver there are usually three different connections, Optical, RCA coax, and RCA six speaker ( back of the player has six rca jack outputs for 5.1 receiver has six inputs).
If you have only optical invest in an optical switch. They run about $30.
Need codes to convert Australian DVD player into a multi region DVD player
By Seajacb123 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 13th Oct 2010, 02:00 -
Burned DVD Plays On Laptop, LG Player; Does Not Play On Panasonic Player
By Valentin in forum Authoring (DVD)Replies: 15Last Post: 18th Jul 2010, 13:55 -
Subs work on PC/VLC Player...but don't show up on dvd player
By bgart13 in forum SubtitleReplies: 9Last Post: 22nd Aug 2009, 19:06 -
my player blu ray disk samsung bd-p 1400 not player my avchd on dvd-rw !?
By LEONESVIZZERO in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Apr 2008, 10:15 -
How Can I Convert Real Player Video Files To Make Them DVD Player Compatabl
By Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
