Results 1 to 24 of 24
  1. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    hey everyone, i want to send a large file to my friend via internet, he kinda lives across the country, and this is probably the most convenient way. the video file is around 550 MB, and i was wondering is there a way to upload this file onto a web page and have my friend download of the web page? please post generously, and ALL advice is welcome, thanks
    Wow! You got shocks, pegs... LUCKY!
  2. Cut it into chunks as a .rar in winrar.
    Send about 4 meg at a time.
    I know of NOwhere that can take a 550mb file, especially not free.
    There's an email type setup you can get to send 50mb at a time, but I forget the name of it.
    You'd be better off burning a CD of the file and express (snailmail) it.
    Cheers, Jim
    My DVDLab Guides
  3. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok thanks u sure, i have got no other altenatives?
    anyway thats ok i know on MSN messenger you can send i think up to 1 GB at a time to someonewho is online as a transfer, ill just get him to create an account, he he...thanks anyways.
  4. Member Xylob the Destroyer's Avatar
    Sep 2004
    Earth, for now
    there is a program called SendLink that lets you set up a 'hyperlink' and email it to your friend
    he simply clicks it and downloads directly from your PC, kinda like a P2P or something along those lines
    http://www.computerknacks.com/sendlink/index.php
    "To steal ideas from one person is plagiarism; to steal from many is research." - Steven Wright
    "Megalomaniacal, and harder than the rest!"
  5. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    If you're on broadband, you can set up your own computer as a server using no-ip.com
    What you do is register with them, then they let you sign up with yoursite.no-ip.org (or .biz, .net and others)
    Windows XP pro has a built-in server, or you could use Apache. It may take a bit of work to set up the whole deal, but in the end, you always have a way to send those ginormous files.
    There's always P2P, or even bittorrent. Just install BT and make a torrent file, email it to your friend, then let him dl the file (after installing BT).
  6. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    any of this cost anything?
  7. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Convert it to binary and fax it to him.
  8. Member glockjs's Avatar
    Feb 2004
    the freakin desert
    i kinda had the same question not to long ago. but mine was more towards directly transfering the file between 2 computers....some good responses : https://www.videohelp.com/forum/viewtopic.php?t=260589
  9. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    can u please elaborate on that process that sounds pretty interesting
  10. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    thanks man!! ima check out your thread and try the ideas out
  11. Член BJ_M's Avatar
    Jul 2002
    Canada
    here - you can send files up to 1GB this way very easy ...
    http://s38.yousendit.com/
  12. That's the place I was thinking of BJ_M
    Cheers, Jim
    My DVDLab Guides
  13. Originally Posted by BJ_M
    Yep, what I was thinking of too.
    Jul 2002
    Up in yo' bitch.
    Make sure the toner and paper rolls are well stocked before sending.
  15. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    is it secure?
  16. Член BJ_M's Avatar
    Jul 2002
    Canada
    is it secure?
    yes - secure in that only you have the link it will give you ...
    if you want more security - they have SSL , same thing but encrypted sessions .. link is there on that page
  17. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    ok thanks, i just sent something and it seems to be working. question however, for those who have used this, how long does it usually take (high speed internet) to send 1 GB?
  18. What's your upload cap?
    How fast and how far away physically is the server you're sending to?
    Are you sending compressed, or raw data?
    Too many variables, but it'll take awhile to send a gig, no matter how fast.
    You'll probably download it 4x faster than upload, especially on ADSL.
    Cheers, Jim
    My DVDLab Guides
  19. Член BJ_M's Avatar
    Jul 2002
    Canada
    what he says ^
  20. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    What's your upload cap? (um whats that)
    How fast and how far away physically is the server you're sending to? (how can i find out)
    Are you sending compressed, or raw data? im sending an avi file, whether raw or compressed i dont know
  21. Video Restorer lordsmurf's Avatar
    Good disc .... 35 cents.
    Envelope ... 5 cents.
    Postage ... 60 cents.
    Total cost to just mail it to him ... $1
    Do that.
  22. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    i gotta send to CALIFORIA
  23. Member skip2mylou's Avatar
    Jul 2003
    In the river Ness
    plus i dont want the disk to break
  24. Upload cap is the maximum amount of bandwidth your ISP allows you to SEND. ADSL is usually one quarter of your maximum download bandwidth.
    Cable can be between 1/4 and 1/2, but usually on the lower end.
    Try www.dslreports.com and use their bandwidth tester to find out.
    Find the server: if you know it's URL, then you can open a DOS box, and type: ping the.url.here
    It will show you the IP of the server.
    You then type: tracert the.ip.you.got
    It will show you how many "hops" it takes to get to that server from your computer.
    More is worse, especially if they timeout.
    Avi is semi-compressed data, depending on the codec used.
    Hint: Stick the disk in a plastic holder, inside a bubblewrap, pay $1.20 for postage, and it'll still get there in one piece.
    Cheers, Jim
    My DVDLab Guides
