Hi, I have successfully create VCD subtitle movie. I have subtitle problem being too low right to the buttom of TV and need to be adjust bit higher. The software I have been using's Subconverter to convert srt to ssa and the option they have is if I want to place sutitles to Top, Centre or Bottom(Too Low)of the screen. I have followed the same way to added subtitle from this link here
http://www.vcdhelp.com/srtsubsvirtual.htm
What can I do to lift the bottom subtitle bit higher from being too low? Which proggies will help that?
When you convert SRT to SSA, you can choose the height of the subtitles.
in the field "distance to the borders" , the default for "down" is: 10 pixels. Change this to (for example) 20 or 15 pixels.
The Dutchman
subtitle problem
By cloudsong in forum Newbie / General discussionsReplies: 1Last Post: 27th Jun 2011, 16:18 -
Subtitle Problem
By cyberlion in forum SubtitleReplies: 19Last Post: 24th Jul 2010, 09:44 -
My new subtitle problem
By pensioner in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2010, 03:32 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
a problem with subtitle
By matrix man in forum SubtitleReplies: 1Last Post: 15th May 2007, 13:36
