When I take video from my camcorder and edit it with Pinnacle Studio 8, I find it difficult to get the audio, the music and sound effects to stay at the same volume. If I save all the audio as a wav file, is there a program I can use to keep the volume at the same level without distorting the audio quality? Could I do it with Audacity?
Thanks. Is the effect the 'Dynamic Range Compressor'? Should I change any of the settings or leave them as they are?
How does this work? There has to be some sounds louder than others, otherwise music couldn't fade out.
And how is this different than the normalize effect? -
Try The Dyamic Range Effect with the settings half way up. Obviously, work on a backup copy of your WAV file.
As I understand it, Dyamic Compression makes the quiet stuff louder and the louder stuff more quiet - so the volume stays more level. Normalization seeks to ensure the loudest passage in a file never goes above 0db.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Low audio volume
By Daz_uk in forum Capturing and VCRReplies: 0Last Post: 29th Jan 2010, 13:34 -
Sony trv 18 no internal speaker volume, no headphone volume
By websbymark in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 5th Oct 2009, 11:39 -
how to increase the volume of the audio?
By sharmine in forum Newbie / General discussionsReplies: 1Last Post: 22nd Nov 2007, 05:45 -
Increase Audio Volume?
By ambrosechapel in forum ffmpegX general discussionReplies: 6Last Post: 7th Nov 2007, 08:05
