I have Sonic Foundry Soft Encode and Digigram AC3 encoder, as well as Adobe Audition. Is there any method I can create 2.0 surround sound tracks using what I have? I can do 5.1 easily, but I wondered if I can do it for 2.0 tracks? Do you do something like invert the stereo sound wave that you wish to be the surround material and then mix-paste that over the regular stereo sound?
I just wanted to try it, 5.1 takes so long to do, something less stressful would be nice!![]()
Thanks in advance.
Results 1 to 19 of 19
To create true dolby prologic surround (or plII), you still mix multiple channels (i.e. 4 or 5 base channels), but at the encoding stage these are encoded down to 2 channels with embedded timing tags. I believe Surcode may have software to do this, but I don't believe soft encode can. It certainly is too old to be able to do pro-logic II.
I know that Sony's current AC3 encoder (works with Vegas, Soundforge) can produce pro-logic stereo output, but only with mono surrounds (i.e. NOT pro-logic II).Read my blog here.
Thanks for the reply.
Mono surrounds would be a start - thats Pro Logic I, right? How do I get Sonys AC3 encoder and what Soundforge do I need? -
click options & encode settings..
i cant believe someone who spent $1000 on this program doesnt know shit about it.. -
Originally Posted by lumis
Besides, I dont recognise that screenshot, must be from a different program or version. And my question is not about encoding to AC3, its about preparing the wave files FOR conversion to AC3. Also, the "Dolby surround - not indicated" box is always grayed out on my Digigram settings. -
There is a difference between 2 channel dolby AC3, and dolby pro-logic/pro-logic II. AC3 2 channel is simple stereo. There are no surround signal emcoded in this, although most amps will have DSP abilitie to create a matrix surround environment from any stereo source. Dolby Pro-Logic/ProLogic II have surround information encoded in the stereo signal.
If you want to encode Dolby ProLogic (not ProLogic II - Soft Encode is too old for that), use the drop down on the BitStream tab (the right-hand tab on Lumis' image (above) marked Dolby Surround Mode and select Dolby Surround Encoded. You will only get value from this if you have the extra channels, so there is almost as much effort required as doing a full 5.1 mix. (Obviously you're not getting your $1000's worth either, Lumis).
You get the AC3 encoder from Sony as an add-on to Sound Forge or Vegas. Sound Forge is now on version 8.0 (newly released). Look up sound forge or vegas i the tools section to find the links. The biggest advantage of the AC3 plugin (which replaced Soft Encode sometime ago) is that it is 3 - 4 times faster than soft encode. I haven't looked at SF 8.0, so I don't know if it supports multi-channel mixing. I use Vegas for it and it does a very good job.Read my blog here.
I'll look into SoundForge if this means it will allow me to make ProLogic tracks.
Thanks for your help. -
The screen shot that Lumis posted is from SoftEncode. Sound forge will probably restrict you to 2.0 channel AC3. You can tag these as PL, but they wont have true surround channels. You would need Vegas to do this, as it can do true multi-channel editing.
Read my blog here.
I got it before you posted
Thanks tho.
Program seems very basic for what I wanna do but was interesting nonetheless. -
Yeah, my question really means how do I encode four channels into two? I did it by accident the other day and now I cant recreate it! I think I inverted the right channel on the speech and when I played it back via my PLII system, the speech came out the rear speakers!
Very odd!
nuendo surround edition does prologic I/II,
so does Soundscape and Minnetonka prologic encoder ...
they are all around 1000-2000 $
a few others also ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by GavSalkeld
For anyone interested, here is a cool Stereo-to-Surround Sound (6 channel) guide on doom9.
http://forum.doom9.org/showthread.php?t=83752 -
https://www.videohelp.com/tools?tool=HeadAC3he
I think this is what you are looking for. I use it to take my 5.1 AC3 files to "Dolby Stereo Surround" wav files. They can work either as analog files or can be encoded to stereo AC3 with the "Dolby Surround Mode" set to Indicated as shown in the screen shot Lumis posted. That will make it Digital Dolby and automatically set the decoder (computer, reciever etc.) to Prologic mode.
You may need to get some supporting encoder/decoders but they are linked from the documentation. -
I've got a ProTools TDM rig with DolbySurround/ProLogic (not ProLogicII) encoding plugins. Works great, but $$$.
If you're stuck without $$ to get a system or plugins, here's a close workaround:
Using a Multi-track editor,
add in your [L]tracks and pan 100% hard Left, Volume 0VU
add in your [R]tracks and pan 100% hard Right, Volume 0VU
add in your [C]tracks and pan Centered (50%L/50%R), Volume -3VU
add in your [S]tracks twice, and pan 1 100% hard Left and the other 100% hard Right, Volumes all -3...-6VU
Make sure one of each [S] pair has it's phase inverted (reverse polarity)
Make sure also that all [S] pairs each have added LowPass (HiCut) filter set to a cutoff freq. of 7.5kHz
Also you could have an option for all [S] pairs to each have added a Delay tap (where the whole signal is 100% wet delayed--no echoes/mixing) set to a few milliseconds (late relative to the undelayed channels).
That's at least 4 mono/stereo tracks (5 if you count the duplicated [S]), mixed down to 1 stereo track.
HTH and Good luck,
Splitting AC3 Dolby Digital 2.0 (surround) into seperate WAVs?
By Asaki in forum AudioReplies: 2Last Post: 29th Apr 2011, 14:18 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 22:32 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54 -
Dolby Digital Surround EX encoder
By grasswhopper in forum AudioReplies: 1Last Post: 17th Aug 2007, 23:49
