i am capturing in Pal from a VCR in Studio 9. is there a setting that i can output in ntsc?
and
i have some clips, and i cannot mix pal with ntsc in studio; is there a trick around this (without encoding)?
thanks
Okay, i'm kind of at a loss here.... WhyOriginally Posted by maansingh169
More info please.
you are capturing in pal, how ? -
I think he has pal vcr and capturing to his computer???? I don't think he can mix and pal and ntsc.
Ranjith -
I kind of figured that but i don't like to assume
because he could be doing acouple of diff. things that's why i asked to make sure... people need to be more clear and give specific details
And if he is capturing from a pal vcr to his pc i would think he could set the capture to NTSC regardless of what the source is, so there would be no need to re-convert it to ntsc.
And he say's
so here again i will assume he is asking if he can make the (output) capture NTSC... but again...is there a setting that i can output in ntsc
And seeing as no one else has touched this in 4 days...
Well he may be lost....
But I do have a question for u, I have a movie.mpv file which is PAL I want to Resize the video to 720x480. How can I do this? Because I am going to use DGPulldown to convert 25fps to 29fps
ThanksRanjith
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 21:08 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL VCR with true NTSC Output (not PAL 60)
By Area88 in forum RestorationReplies: 31Last Post: 12th Aug 2008, 17:55 -
Premiere PRO - NTSC DV to PAL MPEG output
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 12:06 -
Capturing PAL VHS and DVDs to NTSC DVD
By joelkranz in forum Capturing and VCRReplies: 1Last Post: 30th May 2007, 16:11
