Results 1 to 15 of 15
  1. i have a few phones i want to unlock.
    Nokia 3390
    Motorola v551
    Sony ericsson t637
    if anybody knows of a software name and what i need (cables & etc.) and a guide if possible....
    thanks ahead of time
  2. Member jackal70058's Avatar
    Jul 2004
    Louisiana
    I believe there had a website, http://www.cellphonehacks.com/, that had something on it about doing this.
    I've never done it but I know some people have. With some phone you can actually do it without having to link it to a computer but usually you have to.
    You'll need the link cable to link you phone to you computer. Some can get at RadioShack or CompUsa, if not go to you cell phone provider to get it.
  3. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    Nokia should be easy. Go here and dld the software. http://www.unlockme.co.uk/downloads.html
    As for motorola and Sony Ericsson, you will need a data cable and software to unlock those. They can't be unlocked using the phones keypad like the Nokia's can. Sorry.
  4. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    you only get 5 attempts with the Nokia via the keys, after that it's cable. I gave up on unlocking mine and just paid someone to unlock it instead
  5. I was going to ask somthing about this to day. Is unlocking a phone mean,it can be used witha nother carrier?what if there is a balance owing on the phone does unlocking affect this to?
    I'm asking because my wife bought a Phone on Ebay and when we went to connect it they said that the Money owing had to be paid.
  6. Retired from video stuff MackemX's Avatar
    Nov 2002
    VIP Lounge
    that's probably a liittle different and they would probably block your phone completely. You may still be able to unblock it for other service providers though, If this doesn't work you could also contact them and say you are the new owner of the phone and give them the details of the person you bought it off. It may also depend on the phone's history though
  7. Member northcat_8's Avatar
    Mar 2003
    Chit, IDK I'm following you
    If it is a phone from the same carrier, you should be able to just switchout your SIM card.
    I'm also wanting to know exactly what does "unlocking" a phone mean?
  8. ok............i unlocked the Nokia phone.
    now i got the cables for the Sony and the Motorola.....what next...what software do i need.
  9. Member shelbyGT's Avatar
    Oct 2003
    Kansas City, KS
    I'm with you. lol, no really... I'm clueless as to what it means.
  10. Member pyrate83's Avatar
    A phone is "locked" so that it can only be used on that service providers' network. So a Cingular phone isn't meant to be used on T-Mobile or any other GSM carrier unless it is unlocked.
  11. Does Still need to be Unlocked if the phone uses a "SIM" card?
  12. Member pyrate83's Avatar
    What are you asking?
    If your asking whether the phone needs to be unlocked if it uses a SIM card the answer is yes. Once the phone's unlocked you could take a T-mobile SIM and put it in a Cingular phone and the Cingular phone would then recognize the T-mobile network.
  13. That's what I was asking.....Thanks
  14. Member pyrate83's Avatar
    No problem.
