Page 2 of 2
FirstFirst 1 2
Results 31 to 40 of 40
  1. What do you need avisynth for?
    Cheers, Jim
    My DVDLab Guides
  2. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Originally Posted by tony_y2k5
    all i need to know now it how to work avisynth!!
    Well invested effort and time, IMO!
    /Mats
  3. If the source needs major filtering, then I agree.
    If the source is good quality to begin with, then you don't really need it.
    Cheers, Jim
    My DVDLab Guides
  4. Avisynth is a script based program. You need to create an AVS file with all your settings and the files they are to be applied to inside. You then open said AVS file with a program such as Vdub and voila, your video is transformed.
    "Rarely is the question asked: Is our children learning?"
    George W Bush - Moron
  5. er..0o cool. i figured out avisynth heh heh its all good. but now..theres no sound...i dont know why! it was all going smoothly until i burnt it and no sound..and just now iv encoded the file again , and i played it , no sound came out.. whats the problem?
  6. Do audio separately.
    Rip it from the avi in virtualdubmod.
    Transcode in ffmpeggui, or with tmpgenc's ac3 plugin.
    Load it up with the new video into your authoring app.
    Cheers, Jim
    My DVDLab Guides
  7. ic cool , hm..but im wondering how comes no sound came out? cos from my past messed up encoding the sound worked ? but the difference was i put the average bitrate lower..hm..
  8. anoter question...i encoded 3 video files , it came up to 4.19gb . ok thats fine. i authored it. came up to 4367. which was pretty high. i outputted it and the file came up to 4.6 - 4.7gb. im like...what the hell. how did this happen? (yea i used the Video Bitrate Calculator)
  9. How complex are your menus? Any motion menus?
    Not to worry, you can just run the whole thing through DVDShrink to make it fit.
    Next time, leave more room for authoring
    Cheers, Jim
    My DVDLab Guides
  10. ok cool thnx :P
