I thought it would be a good idea to start a thread on peoples conversion speeds. Please include your method and time per section (eg. rip, frameserve, encode) and also what system you are using.
Iam using an AMD Thunderbird 1Ghz 266Mhz FSB, 256MB RAM, AK37-A Motherboard.
RIP- Smartripper, 25mins.
Frameserve - DVD2AVI - 2 Hrs (using 64bit floating point)
Encode - Using Tmpeg - 4 Hrs
Just a comment, shouldn't you also include the movie length? Seems a bit pointless to say how long to rip / encode when you don't know the length of the movie or indeed what type of movie. Just my 2 cents.
cheers,
blah....movie length actually has nothing to do with rip time...i've seen 120 min movies with smaller size vobs than 90 min movies....gotta include the filesize
also, certain features also increase the time...i.e.
smartripper -> enabling demacrovision increases time
dvd2avi -> downsampling, normalizing increases time...and also the higher bitrate audio you extract, the longer it'll take cuz the resulting .wav will be bigger...i.e. 448 kbit audio file >>>> 128 kbit audio file
tmpgenc -> cq_vbr or 2 pass vbr...makes a big difference....also blend (adaptive) >>>> blend big time...., etc..
<font size=-1>[ This Message was edited by: poopyhead on 2001-12-10 21:35:38 ]</font> -
XP1600+,256Mb,40Gb 7200rpm
100 min movie
Smartripper: <10 min
DVD2AVI: 10 min
TMPGEnc: 2h 15m
Athlon 1000, 384mb SDRAM PC133, 45gb 5400RPM
Movie - Superman Special Edition - over 2 hours
Smart Ripper - 15min
DVD2AVI - 15min
TMPGEnc - 5 hours
Total - 5 hours and 30 minutes.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
1.3 P4 384 rambus memory 400 Mhz fromtside bus, 40 G 7200 RPM.
movie 2 hrs 20 min, 7 vob files 6 each .99 GB and the last one 22 MB
CLAD DVD to rip dvd to hard drive - < 10 min
DVDx1.6 to VCD files 7 hrs 27 min
may be my settings are in correct. i set every thing to normal
For what its worth (I've got bag's of time)
Athlon classic 600 clocked @ 750. Fireball LM+ @7200 ATA 66. 512Mb PC133 ram. ASUS K7M+ Mobo. Afrey 10x Dvd Rom.
Using: (Biggist film GLADIATOR) (With dir cut in over 2hr's)
Smartripper (15min)
DVD2Avi (14min)(Sound only)
SSRC (In TMPGEnc Aprox. 15mins)
TMPGEnc (7hr43min) (Settings to max VCD Standard Quality)
Myflix (4min to split in half)
Nero (Aprox 30min to burn both discs)
Going to upgrade in the new year as my bro. now has clocked athlon 1690Mhz doing same as above, but nearly in real time.(And Yes I stoop my head in shame when he call's to gloat)
Have Fun
Audio track speeds up going from AVI to DVD
By jenna1 in forum ffmpegX general discussionReplies: 2Last Post: 19th Oct 2011, 15:22 -
Burning speeds
By Rogert in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2008, 07:28 -
DVD burner read/write speeds
By ecc in forum Authoring (DVD)Replies: 9Last Post: 13th Apr 2008, 05:49 -
DVD Decrypter / DVD Fab - Extremely slow ripping speeds in Vista
By awp in forum DVD RippingReplies: 5Last Post: 19th Dec 2007, 13:11 -
Burning speeds and DVD Decrypter...
By Nilfennasion in forum Newbie / General discussionsReplies: 6Last Post: 20th May 2007, 04:32
