Can anyone tell me what the best way is to burn a DVD from avi files?
Thanks.
Many has spoken on that subject. Depending on the properties of the AVI files, different methods and approaches might be needed.
/Mats -
VSO DivXToDVD seems to be the easiest way to me. It says DivXToDVD but it seems to handle most AVI and MPEG files. If you want to use freeware only then you can use DVDshrink to join the VOBs and DVDdecrypter to burn the DVD. If you want to add menus, then you need to buy an Authoring program like TMPGEnc DVD Author.Originally Posted by nathanhall
crack region code on avi files to burn to dvd
By wilbureduke in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2010, 22:12 -
Burn .avi files as what type of dvd for playing on PS3
By VenGeanCe in forum Newbie / General discussionsReplies: 4Last Post: 15th Mar 2010, 18:56 -
Which DVD should I use to burn avi files to play on standalone?
By Stealth3si in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2009, 11:22 -
Some Avi files will burn on dvd, others won't??????
By Qvezzy in forum Newbie / General discussionsReplies: 3Last Post: 6th Jan 2009, 11:47 -
Compressing AVI Files to Burn to DVD?
By ryevick in forum Authoring (DVD)Replies: 17Last Post: 27th Nov 2007, 22:59
