OK. I've been re-encoding vids and such for a couple years now so i know a little bit, and can usually fix my own problems. However, i have a new issue i can't figure out.
I have occationally downloaded and burned,or did a re-encode with WinAVI and gotten this problem. I put the DVD in my player. It starts to play but it looks like the tracking is off really bad on a VCR. I press stop and the DVD player is doing the same thing on it's main screen. I have to turn it off, then back on to get rid of it. Now these vids work in somebody elses DVD player that i know but it messes mine up. If anyone knows what this could be, it would be a huge help.
Figured it out. My DVD player wont play PAL. I did a few tests it all leads to that. I guess i'll just have to go back to using Tmpgenc and virtualdub to encode my AVI downloads instead of WinAVI. I blame me for assuming that movies are NTSC when the uploaders are not marking thier stuff proper. Anyways i took your comment into suggestion but it all led to PAL/NTSC. Thx anyway for your help. : )
What program can I buy so i can make a vid like gopro hero2 vid
By DROCK71 in forum Newbie / General discussionsReplies: 5Last Post: 21st Mar 2012, 14:01 -
[Closed] Vid capture problem- aud/vid synch issues...?(Dazzle VidCreat+HD)
By Diana (Cda) in forum Capturing and VCRReplies: 2Last Post: 22nd Dec 2011, 11:50 -
downloading a vid from radio-canada.com, but vid isn't available for dwld
By vivimarie in forum Newbie / General discussionsReplies: 4Last Post: 23rd Oct 2010, 12:48 -
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
Vid encodes will only display first frame instead of loop at the end of vid
By SignedupGuest in forum Newbie / General discussionsReplies: 6Last Post: 8th Aug 2008, 23:09
