I'm finally ready to complete a DVD-9 and need advise on which SCSI card and DLT drive to get. I'm running a Dual 1.25 G4 and DVDSP 3.
Thanks in Advance--
Atto might be good card, it's also used by Apple. Adaptec seems to have poor Mac support. Initio would be another good card.
i-NCO -
And Sony or Tandberg might be good drive. Most brands are rebadged Sonys, I think...
i-NCO -
most DLTs are made by quantum (HP, Sun, IBM, compaq and others) ... I used SUN and Compaq units mostly.
DLT 7000 and 8000 are the most compatable and cheap(er) now.
you can also rent them for a day or week in most large cities ..
for dvd-9 use only , a DLT 4000 is all you need .. you will need two tapes ...
for the mac - the atto i know works. which one depends on the model of DLT you get."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Quantum DLT8000 & SCSI card Available
By sdsumike619 in forum Authoring (Blu-ray)Replies: 1Last Post: 6th Dec 2011, 17:07 -
Ready to buy and need advice please
By steve84 in forum Capturing and VCRReplies: 13Last Post: 8th Aug 2010, 20:09 -
ADVICE ON WHICH TO BUY
By shimmie in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th Aug 2010, 20:05 -
Ready to buy new PC. ...looking for advice
By Deku Scrub in forum Media Center PC / MediaCentersReplies: 26Last Post: 9th Nov 2009, 22:44 -
2 DVD-5 Set or buy a DLT ?
By sdsumike619 in forum Authoring (DVD)Replies: 10Last Post: 2nd Aug 2007, 01:03
