I think I read about someone having a similar problem, but I could not locate it anymore on this forum.
I had just recorded on a +R and HAD NOT finalized the disk yet. I inadvertantly pushed eject on the remote and when I closed the drawer back it would say "preparing" disk and stayed this way for at least five minutes. Then when it finished it said on the top "data disk". If I try to browse what is on the disk nothing comes up. I have the 1193 firmware installed.
So, is this disk a coaster now? If so, let this serve as a warning to other ILO owners, do not eject the disk until you have finalized it.
In the beginning, I loved my ilo, now I am starting to get discouraged.
Any suggestions, fixes or comments would be appreciated.
I had a LiteOn 5101 (same company makes the ILO) and if it locks up or ejects when writing to the DVD+R, then I end up getting a coaster, especially if I had to unplug it when it locked up during recording. But most of the time I can leave the disk unfinalized and use it as much as I like without a problem. It's that 1 in 100 chance that will damage your disk. Once I got the coaster, I found no way to get it back. Sorry.
I eject my discs all the time without finalizing with no problems. It must have been a user mistake.
carter2004,
Has this happened only after the upgrade to 1193? If so, HOW did you upgrade? There are now two parts to 1193, A and B, if you only install part B (the latest firmware version) you won't get the DVD drive updates that were part of 1193-A. Maybe this has something to do with it?Proud Member of the Unofficial LiteOn/iLO Beta Testers Club. -
Harpmaker:
It is possible that I did not upgrade to both a and b. The setup screen only shows (0193), so I will redo them and see if it makes a difference. It happened again last night so it is not a user error, but I sure hope redoing the firmwares will correct it because I was on the verge of heading over to Wally world (even though its past 90 days) ! Thanks for your help, I will post as soon as I do the reinstall -
Harpmaker: Hail to the KING!!! You were right on the money!!! Thank you Thank you Thank you!!!
From what I could tell I updated with the 1093 A version then when the B version came out I had not updated to it. So apparently, if you only do the A and not the B and you eject the disk it will not let you finalize it or add anything to it. So I updated with the B version tonight, recorded on a disk for thirty minutes, ejected it without finalizing and reinserted the disk and WHAMOO!! It saw it!
I am so thankfull for this site and all the helpfull members!! Thanks Again Harpmaker!!!
Can't finalize BD-RE?
By DGenerateKane in forum MediaReplies: 0Last Post: 23rd Sep 2009, 18:45 -
Problem with Seagate Disk Wizard
By bevills1 in forum ComputerReplies: 13Last Post: 11th Apr 2009, 05:51 -
Burning project to disk problem
By NP11073 in forum Authoring (DVD)Replies: 3Last Post: 26th Jan 2009, 01:15 -
Disk Finalize
By arobertson1 in forum DVD & Blu-ray RecordersReplies: 28Last Post: 4th Sep 2008, 18:28 -
finalize Help
By whittyscosie in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2008, 13:27
