i have been burning DVDs with DVD X copy with no problem until today. when it asks to "Start" the burn, i now get the error messages "Cannot Write Archive.txt", "Unable to Create Vob", and "ErrorIfo"
i have uninstalled and re-installed the program with no success. also, after re-installation, it doesn't ask to re-enter the ID or password numbers. Which means it has left something behind on the computer on uninstall.
anyone have any ideas what the problem might be?
thanks
your problem is you need to take that software and throw it into the trash....
How Big A Boy Are Ya? -
I agreeOriginally Posted by ghoster
Use better software -
besides the above comments, just make sure the temp directory actually exists..if you specify a dir that doesn't exist, I think it chokes...
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole." -
DaveS,
It worked. The temp folder was not there, so i made it and it worked. I can't believe I missed that one. Although, I have never had that happen in any other burning software that i have used. Thanks.
As for hecklernumber1's reply; AnyDVD didn't work.
As for ghoster's reply; I agree that the software should be thrown in the trash, except that it is the only one out there at this time that will burn DVDs. I say that because when I burn on the $1 Ritek DVD+RWs, which i have been using for the last year and burning with Nero trial versions with no problems at all, there are an extreme amount of glitches with X Copy. Using $2 DVD+R Memorex and burning with X Copy produces less noticable glitching (but some). Also FYI, the X Copy burned movies do not play in my RCA recorder/player but do play in the sister's Sony player.
If anyone knows of another DVD burner, please let me know. Nero's new version doesn't burn DVDs anymore. Nero doesn't sell the old versions anymore, and the only ones available that I can find are the OEM versions. I bought one and it doesn't work on my system.
Thanks -
^^ I don't get the last 2 paragraphs. You're saying DVD X Copy is the "only one out there at this time that will burn DVDs" This is 2005, there are tons of programs that burn DVDs. My choice being DVD Shrink combined with DVD Decrypter, both free! Also, shouldn't this be in DVD to DVDR?
copy You Tube to DVD,sound leave problems..
By gary153 in forum Newbie / General discussionsReplies: 1Last Post: 16th Oct 2010, 08:33 -
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 13:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 08:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31
