Hi I'm looking for some help if poss.
I'm having probs playing back some DVDs on the PC although they play fine on standalone DVD player. There is no audio.
When I've put them through G spot it says that the audio is LPCM.
Problem is I don't know how to fix it and can't make head nor tail of what comes up when I go into Google.
Can anyone help me find an appropriate codec or help me fix please?
Thank you for reading
Results 1 to 16 of 16
Thank you for taking the time to reply.
I'm not sure where I go from now then as it definitely will not play on my PC but does on the standalone.
Mmhh - I'm stuck -
Actually, LPCM is the RAW headerless data. It can be wrapped/headed as WAV or AIFF, etc. Nevertheless, you should have no trouble ever playing (Headered) 16bit/48kHz/Stereo/LPCM files on any modern PC/Mac--as long as there are no pipeline bottlenecks (e.g. tacked onto HDvideo), or too many processes. Sounds like somethings wrong with your DVD decoder/player app.
Scott -
Thanks Scott for bothering to reply. Much appreciated.
If I get it sorted I'll let you know for sure what the prob was. -
What s/w are you using on your PC. Try Media Player Classic.
When I was born I was so shocked that I could'nt speak for 18 months. -
Hi HMFC,
I had the exact same problem as you once.
It turned out to be the audio out of my DVD ROM wasn't connected to the audio in on my motherboard.
Or, it might be that (if you've more than one DVD drive) the one your using doesn't have the audio output hooked up.
You never know. Anyway, I hope it's something as simple as that...There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
That would be the case if you were trying to play AudioCD's in those drives, but not DVD's.Originally Posted by daamon
AudioCD decoding is done in hardware in the CDROM drive (as it's simple algorithms) and sent out via the analog jack(s) on the back of the drive, as well as the mini-headphone jack at the front (on those models that have 'em).
DVD audio decoding is done in software or, rarely, hardware cards, much further down the line. The disc's databytes are sent to RAM-->DVDPlayer/Navigation-->StreamDemuxer-->Audio(as well as Video)Decoder-->OS Mixer-->Soundcard Output. (That it roughly)
You'll note that it's not possible to have DVD audio come out of the headphone jack--try it.
Could be DTS tracks and your DVD player app doesn't support it...
Get DVDDecrypter. It'll tell you # of and what type of streams there are and what formats. Look in "Stream Processing".
Scott -
Really grateful for all the suggestions folks. I'll keep trying to find an answer.
And I thought women were complicated! -
Ah ha - ran the disc through DVD Decrypter and its LPCM 2 channel. Tried the disc through Windows Media Player (I usually use Real One) and it works perfectly. Obviously its a Realone issue then.
Many many thanks people. -
If you run a date through WomanDeCrypter v1.0, I wonder what type of protection it'll remove?
8)
Scott -
No it couldn't be copy protection because it was family holiday videos. I'd put them on tape years ago and thanks to the advent of PCs and DVD Recorders I managed to get them on to disc but couldn't play the damn things on my PC.
Now resolved. Yee haa. Also means I can do copies for the rest of the family easily and quickly. -
Sorry, I was trying to make a stupid double-entendre. "Women" / "Copy protection"...Ok, time for me to stop. Wasn't that funny.
Scott -
I got it. Thought it was quite good actually, if that's any solace...
Carpe diem.
how to convert mp2 audio to lpcm?
By gareth41 in forum Authoring (Blu-ray)Replies: 9Last Post: 21st Oct 2011, 13:47 -
Need Help Converting Audio 44.1KHz LPCM flac to 48KHz LPCM + Add to DVD
By nagysaudio in forum AudioReplies: 2Last Post: 5th Oct 2010, 09:15 -
LPCM audio not recognized in tsMuxeR
By ITISRAVI in forum Blu-ray RippingReplies: 1Last Post: 4th Oct 2010, 08:34 -
How to Demux LPCM audio from TS
By iker222 in forum DVB / IPTVReplies: 3Last Post: 6th Aug 2009, 17:16 -
is LPCM the same as PCM, for audio?
By runLoganrun in forum Newbie / General discussionsReplies: 14Last Post: 6th Dec 2008, 19:37
