i was trying this app the other day and i have an avi of 700 megs, i load it in and the program says it needs 18 gigs to process!!!!!!!!! now if i did that and had to shrink it down , what on earth would i be left with, i couldn't even imagine shrinking 18gigs to 4.7. is this right? and if not, what app can i use to do the trick of converting avi to dvd, part 2 is avi is 23.9 fps so convertinh this what would i have to do to smooth out the motion, it plays like jerky jerk on my pc already.
kicko-
Avi2dvd needs all that space for the entire conversion process it does, NOT for just the finished file. One of the issues I have with this app is that I can't seem to be able to save the finished files where I want, but only to the same folder the souce is in. Extremely limiting, unless I've missed something.
Anyways, try doing a conversion on a drive with enought freespace, & you will see that the results will be a size to fit a DVD5.
AVI2DVD problem
By Electroniks in forum Video ConversionReplies: 3Last Post: 26th Aug 2008, 14:41 -
Problem with Background sound using AVI2DVD
By govtstooge in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 14:11 -
avi2dvd problem
By cr2007 in forum AudioReplies: 3Last Post: 17th Nov 2007, 07:49 -
avi2dvd problem again..
By aruwin in forum Video ConversionReplies: 2Last Post: 22nd Aug 2007, 02:12 -
AVI2DVD Problem
By gonwk in forum DVD RippingReplies: 1Last Post: 12th May 2007, 22:08
