Results 1 to 29 of 29
  1. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    2.0 RC 7 - Released 21 March 2005
    ! Image menu button selection bug when loading a second image – fixed.
    + NeroBurner now has a burn speed option.
    ! pixilation on some mpegs from capture cards – fixed.
    * slightly different avi to mpeg encoding to improve quality.
  2. THX for your hard work to improve Svcd2Dvd,ChrissyBoy....
    Some major companies should take an example of your dedication...
  3. Originally Posted by ChrissyBoy
    Could you please elaborate on these? Are you using a different mpg encoder?
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    no just different settings/parameters
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
  6. thanks chrissyboy, will give it a try tonight.
  7. Heya CB,
    Just tested RC7 and the menu's work fine
    Cheers on such a quick fix
  8. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    The encoding tweaks on this release are primarily on the back of your observations... Any thoughts?
  9. Any tweaks done (or planned) for audio? I'm still having that audio problem. Even though it seems to only happen with one particular player, the fact that it worked ok on that player with 1.5 indicates that it *is* possible... What changed in either the audio or multiplexing routines between 1.5 and 2.0?
  10. hallo
    much appreciate, but i can`t deinstall my svcd2dvd rc6. problem is i get an error "svcd2dvd rc6.msi not found"..
    my registry cleaner have made good work
    anybody can send me the original installer svcd2dvd rc6, then i am capable to deinstall rc6 and to install the latest rc 7.
    without the original installer i have no chance
    many thx
  11. I can email it to you.. but there is no email in your profile...
  12. hey Dave H
    check your pm, i wrote you my email
    many thx for your help
    best regards
    slaky
  13. ok guys, my problem is solved, thx to chriss for help ;)) :P
    greetz
    slaky
  14. AVI is much improved chrissy, still some slight artifacts occasionally, but only really noticable if you are sitting up close and looking for them. Excellent Job!
  15. Hi Chris just did a mpeg2 movie and a avi movie on 1 disk used the auto size
    thinkin it would fit on 1 dvd
    i was wrong turned out to be 4.54 gig too big for a dvd
    might be a problem with the bright rate
  16. re did 2 more mpeg 1 movies same thing final size 4.52 gig
    both movie had audio and menus inc no auto size
    used with not bein avi
    does the size thing work before or after you insert menus ie jpegs and mp3
  17. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    were they PAL to NTSC runs?
  18. both same format
    i fixed it
    had to redo with out adding the audio to the menu screen now just fits ok
    might be a good idea to make it so you can only encode up to say 4.3 and not right up to 4.5 so audio can be added to menus
    or a button to workout full size inc audio and menu before resizeing
    cheers brit great program
  19. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    the menu audio is accounted for. (add some ad you will see the capacity indicator change). i suspect it is miscaculating the mpgs. Can you email me the log file?
  20. log file gone chris sorry it was 18 meg and i got rid of it sorry
    i will try to do a few more and send you the log files
    ? any one else havein problems
  21. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    18 mb? Are you converting from PAL to NTSC or not?
  22. no both files where ntsc mpeg 2 and a avi
  23. RC7 works for me just like RC6, although the menues don't work properly on one of my cheap DVD players that also gives a slight letterbox effect (apex). I think the apex is going to be put on a back shelf, since it has other problems too. DVD player compatabillity is a new issue for me with these newly created disks. I also read others posting similar issues with certain players.
    Thanks Crissyboy,
    gealto2
  24. in RC7 is a 1 movie (VTS) set to go to movie only (no menu) or is this bug ?
    ive made 3 dvd's all with 1 movie all only show the movie no menu
    i used quick dvd (no burn option ) is this why?
    also chrissy thanks for adding the burn speed option ! can u raise the speed to 4x
  25. Originally Posted by BabyGonzo
    Yes, with the quick dvd option there isn't a menu created. It's designed that way.
  26. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    It shows your dvd recorders posible speeds in the dropdown. This may change when you have your media in your drive.
  27. ok i'll check it with media in drive .
    with some media ive had max burn at 16x which was to fast for my liking even though my burner is 16 x but the media was only 8 x i dont like to burn at max speed 4 x works just for me and some times if i feel dangerous i'l burn at 8x depending on the quality of the media .
    thanks predator now i know
  28. Got anything Chrissy things getting a lil frustrating now should I re- download
  29. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I shall email you some tests
