  1. i need help i am useing audacity to try and record some lines off of my dvds but i cant figure out how to et it up now i am just poping the dvds in my cd drive and listening to the on my computer speaker how would i set it up to record please help
  2. Member Adub's Avatar
    Mar 2005
    california
    Make sure that you are setting the soure to be the WAVE setting. It records it from your sound card.
    The way you chose it is just above the area were it shows the recorded sample.
    A few other options are Microphone, Line in, CD Player etc.
    Sep 2003
    You might also try "what you hear"
