When I load up a blank TDK DVD-R, it would take a few moments before it would recognize it.
Sometimes, pressed (commercial hollywood) DVDs won't play on it but would run fine on my standalone DVD player.
I just bought a pack of DVD-RWs and when I load them up in DVD Decrypter to burn a DVD (that I created in iDVD on my Mac), I would see at the bottom "Device Not Ready: Incompatible Medium". When I try to pop in DVD-Rs from Memorex, I would get the same thing, which is ironic because those worked in the summer.
Does this sound like a failing laser to you guys?
My ND1300A died in a similar way. First it stopped reading pressed dual layer DVD-ROM, then no more blank/burned DVD and single layer DVD-ROM some weks later. After that again it often had errors even when writing CDs. I guess it will come to full stop soon. I had it checked just after it stopped reading dual layer ROM, the technician said "weak laser, cant fix". So it sounds like failing laser to me.
ok, i just called it dead cause there was a sale at MicroCenter (a small compusa-ish chain). It was a OEM DVD+-R dual layer burner for $60, a deal I can't miss. here: http://microcenter.com/single_product_results.phtml?product_id=0178385 for you people who want to get one.
So I got my new drive and everything is going fine now.
Sony HC3 firewire port dead,cheap miniDV camcorder to use for transfer?
By alegator in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 76Last Post: 13th Jul 2011, 20:59 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 18:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
