I have the PVR500 and I am getting really choppy video. Audio is fine, but the video will freeze now and then. Is there anyway to play with the setting on the card?
Results 1 to 13 of 13
After fighting with beyondtv for 2 days (and at least 4 other TV/Capture apps), I finally deleted it/them. It wasn't worth the effort, for PAY software. Got the latest drivers from www.shspvr.com and installed GB-PVR, with a few tweaks and modules from wiki, and it's the best yet.
Cheers, Jim
My DVDLab Guides -
It uses Microsoft DirectX 9 to put the video onscreen.
Cheers, Jim
My DVDLab Guides -
If Spike is in the "normal" channels, it should show up. Did you register with Zap2it (free)?
This will give you the regular channels, browseable and searchable.
If Spike is coming via satellite, or digital, then you need to map it to a normal channel number. Instructions are all in the help files.
In GB-PVR, go into Config. On the PLAYBACK tab, try selecting VMR 7, or Overlay manager, instead of VMR9. Depending on your video card, and wihch DirectX version you have installed, one of those three options will work.
Try posting your question on the GB-PVR forums at http://gbpvr.comCheers, Jim
My DVDLab Guides -
I used Zap2it and the channel is all static. I will delete the channel list and redownload it.
What have you set the source to?
Set recording source to Direct recording plugin.
Hit the settings button.
Set your country. Source, internal tuner, cable (unless it's really on an antenna). Click OK.
EPG source, Zap2it. Click settings. put in your username and password, click OK.
Wait quite a few minutes for the info to download, and write the correct xml for you. This can take 10-20 minutes, providing you got the specs correct when signing up at zap2it.
If the EPG doesn't update at that time, click Empty EPG, then Update EPG now.
I do this once a week manually, but GB-PVR can also do it automatically whenever you specify.Cheers, Jim
My DVDLab Guides
How can I tweak Vista32 for best Performance?
By nyfsmith in forum Newbie / General discussionsReplies: 0Last Post: 31st Aug 2008, 14:58 -
?uestion about a particular win xp tweak
By mol3000 in forum ComputerReplies: 10Last Post: 22nd Oct 2007, 15:11 -
HSync issue on Composite capture - PVR500
By PDO in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 22:53 -
Tweak My Reauthoring Process...
By oohah in forum Authoring (DVD)Replies: 4Last Post: 3rd Jul 2007, 03:18 -
Comparison: Hauppauge PVR500 vs LG RC7000B
By Caple in forum Capturing and VCRReplies: 5Last Post: 15th May 2007, 19:58
