i have an audio of the movie and i want to sycronzie heim to a movie?
which tool can do it?
and if there is a way to sycronzie a movie by the fps of a movie? and how i check the fps of a movie
by the way all my filles are vob fillles of dvd-r
Results 1 to 15 of 15
You've seen that guy with a clapper? That's how you syncronize audio with video.
VOB files are part of a DVD Video structure, and as such already should contain audio, hopefully properly synchronized.
Do you want to replace the audio in the VOB or what are you trying to do?
If there is no clapper in the video, best way is to find some well defined event, like a door slamming shut, and try to align the audio of that event with the video.
fps can be found for most video file formats with GSpot.
/Mats -
thanks for your respond but i am not really understand what you mean
i have a audio the he is sycronzie and one more audio that i want to sycronzie
there is a way to sycronzie by comeparing the to audio?
or this a way to sycronize the by the fps of the movie?
if there is a way can you tell me white which tool can i do it ? -
Originally Posted by masterMZ
Oh yes.
(Sorry I couldn't resist) -
Just add your audio to the video. Test. If it's out of sync, adjust audio (add silence at start or cut some out), repeat until satisfied.
/Mats -
first of all how can i do it ? and there is program that cand to it?
and again thanks for you respond -
What is your source ?
What tools do you have currently (authoring software, audio software etc.) ?
If your source was a downloaded avi with mp3 vbr audio (the most common cause of sync issues), use virtualdub in full processing mode to save an uncompressed wav file, the reencode this for authoring.Read my blog here.
MasterMZ, it sounds like you are trying to synch a second audio track to a movie that you have ripped to vob's, correct? Do you wish to retain both audio tracks in final movie? You will need an author program that can handle multiple audio streams, for example dvd-lab pro, ulead dvd workshop or I believe dvd author can do this for free. I have done this using the audio delay feature found in dvd-lab pro in "tools" section. Dvd-lab has a steep learning curve, but is very powerful and has excellent online help manual, Here;
http://www.mediachance.com/dvdlab/Help/index.htm
Or you can add silence to or cut few ms from start of audio using editor like goldwave, then import that into your movie during the authoring step. If this is not your intent, then please post exactly what it is you are trying to do so someone can help you. Best of luck. -
First thanks for your help, I will explain my self again
I have download DVD-r movie which contain one audio and I download avi file( after that I separated the sound from the movie )
After that’s I add the sound from the avi file to the DVD-r using DVD-lab and when I watch the movie in the DVD, the audio that I added and saw that it's not synchronized white movie .
There is way to synchronize the movie white the audio? ???
Or there is a way to use original sound from DVD and white him to synchronize the audio form the avi file???
again thanks to all that help me -
The file you downloaded was a DVD converted to AVI, probably in Divx or Xvid form ? Assuming, for the moment, that this is a legitimate, public domain movie, and no copyright infringements have occured, load the avi into virtualdub. Set the audio to full processing mode (Audio menu), then save wav as uncompressed LPCM.
Because you haven't told us what software you have, this next bit will be pretty generic. Load the video into your encoding software. Load the uncompressed wav file in as the new audio track (replacing the original). Things should stay in sync from here on (they do for me, anyway).
If they don't, you need to try and measure how far out they are, and adjust the audio to correct. This might mean adding silence to make it start later, or trimming some from the start to get it going earlier - just as Mr. Hogberg explained earlier. Unfortunately, this bit is hit and miss. I haven't seen an easy way of getting things back together except trial and error.Read my blog here.
you miss understand me i already sperated the audio from the movie using virtual dub
but when i re build the the dvd using the dvd-lab and i put in there the orgianl dound and the sound from the avi filles this audio from the avi fille was not sycronize
you told to put sillence to movie
but how can i do it ? and how can know how much time of sillence to put -
Hey, Hope I'm not intruding. I'm Not an expert but... I did have a sync prob with some of those new movies when downloaded to VOB files with DVD Decryptor. I had to turn VOB to AVi using DVD2AVI, then TMPGENc would recognize audio and video. Teen just preview movie under source range, scroll thru frames and mark when audio starts and when video starts, note difference and plug it in the audio adjust/delay box(which is in ms so use thousands) and then Encode but watch before you burn just to be sure. Also I don't know what your burning but DvdShrink is so easy and just one step for good quality on one disc. Just fyi, hope I helped.
"Those Who Must Be Kept" -
Be sure that the avi and the vobs have the same framerate.
Look the audio delay in avi in GSpot. I don't know if the same can be done for vobs, but you can try. Alternatively you can run one of the vob files through DGIndex and demux the audio - the delay will be written in the file name of the audio file.
Finally look at the duration of both files - if it is different you need to invest more work to fix it.
Taking Audio from movie file, then burning audio to cd-r
By Justnmnmn in forum AudioReplies: 5Last Post: 22nd May 2009, 17:44 -
Movie without audio
By Jomapil in forum Newbie / General discussionsReplies: 13Last Post: 7th Aug 2008, 15:17 -
1 movie 2 different audio
By pcb in forum Newbie / General discussionsReplies: 22Last Post: 26th May 2008, 13:44 -
What audio is in HDTV movie?
By php111 in forum DVB / IPTVReplies: 2Last Post: 2nd Jan 2008, 07:25 -
taking audio from one movie to sync in a movie
By bigdaddykane in forum AudioReplies: 9Last Post: 28th Dec 2007, 13:40
