Hi! I need to know how can i burn a movie so it is in a file when i go to play it on my dvd player.I cant play any of my movies on my dvd players but they work in my pc and my dvd/vcr player.When i play them on my dvd/vcr they turn off after 5mins into the movie.I use Nero to burn to a Dvd disk.Can someone help me please??![]()
BadTast
With not much to go on, I'd say bad/incompatible media.
Could you describe your process in a little more detail?
What is your source material? What do you do with that (every step until you've got a Video DVD disc in your hand)?
/Mats -
Ok i use Cucusoft to change it then i use IFO then i use Nero.When i use Nero i do dvd burn it gives me 2 files Audio_ts & Videos_Ts i then add them to the Video file. I use DvD-RW's disks.If you need more info can you tell me what kind of info you need -) It will work in my friends dvd play just not mine.I know the dvd play works
it might work if the movie is in a file i just dont know how to put it in one.Thank you for your time!
BadTast -
Avoid using words like "it" (i use Cucusoft to change it ) when nobody has a clue as to what "it" might stand for!
It's not easy when you're new to things to know what's relevant and not, but descriptions like:I have an AVI with X fps, YxZ resolution, a bitrate of D, encoded with the xyz codec. The audio is encoded as Q. It's z minutes long. I load it into Z, cange the q setting to p, the w setting to h, and click Start. Then I take the z file from Z output, load it into J and change the U setting and save.
Never used Cucusoft, but that the DVD plays fine in your friends player, suggests a media incompatibility issue with your player. It might not like DVD-RW at all, or not the manufacturing of the DVD-RW you use or... Try other types of media (+RW, +R -R) and other brand/manufacturer of media.
The movie shouldn't be "in a file" for best compatibility - it should be authored as VOBs IFOs and BUPs in a VIDEO_TS folder, so you're on the right track.
/Mats
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 00:56 -
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 18:28 -
burning a dvd from an .avi file and a .wmv file
By marlo in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2010, 06:06 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 05:02 -
how can I convert dvd file on my computer to avi or a different file
By brew in forum Video ConversionReplies: 3Last Post: 19th Nov 2007, 19:21
