I am trying to remove a logo from a file. I can't figure out how to get virtualdub logo and subtitle remover to load and work in the filters. Can anyone help? Go slow if you can help![]()
Results 1 to 9 of 9
What is your problem - loading the filter, or getting it to work ?
To load it, make sure it is in your Virtualdub plugins directory. Start up virtualdub and load your clip. The, on the menu bar, Video -> Filters. Click on Add and select your filter from the list. It should open with the settings page if there are any.
After that, read the help file / readme file / author's web page to get the specifics on the plugin.Read my blog here.
And no, it doesn't remove it completely, of course there is no way to restore what's underneath it.
Hello,
https://www.videohelp.com/forum/viewtopic.php?t=232456&highlight=delogo
That thread covers the "delogo" plugin filter for vdub. It is similar to the built in one. It does a very good job. BUT it's not perfect. As mentioned you can't completely remove a logo. You can get good results if its a small logo AND if it's not animated.
Worth experimenting with though...
KevinDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
replicate dirt on logo removal
By mathmax in forum EditingReplies: 26Last Post: 11th Oct 2011, 18:35 -
Logo removal by using 2 sources
By pfxz in forum RestorationReplies: 13Last Post: 8th Feb 2011, 23:01 -
LOGO removal from WIdescreen black bar
By CBrianA in forum EditingReplies: 2Last Post: 6th Feb 2010, 10:10 -
Good Results on Video to Photo Logo Removal?
By Disco Makberto in forum EditingReplies: 28Last Post: 14th Dec 2009, 20:40 -
Removal of TV logo from VOB files?
By guy24s in forum EditingReplies: 6Last Post: 16th Nov 2009, 23:25
