Hi, I have a wav file that I need to cut parts out of. The two programs that I have tried have given me problems. I chose the segment I want to cut and then the programs ask me to select the output format. No matter what output I choose (wav, avi etc) the new smaller file plays much faster than the usual speed (sound and video). I even tried converting the big wav file into avi first before cutting it but I get the same thing. Am I doing anything wrong?
Thanks in advance
Results 1 to 11 of 11
What programs are you using to edit the sections out of the wav's ?
And when you cut out what you don't want, does it just take the section out and keep the rest together or are you getting 2 wav's and then trying to join them ?
I usually use Sound Forge which is not cheap but it is what i have used 90% of the time for a long time now when editing wav's, and just decided to try GoldWave to see what it can do, i don't get why you would save an audio file as an .avi but. -
I just realized I have asked the wrong question. The file is actually a WMV file not a wav file. That's why I was confused when you guys replied with Audacity and Goldwave. So does anyone know why the new wav file that I cut out goes really fast on playback? Both programs I use give me the same result. Not sure if I am choosing the right settings. Sorry for the confusion again.
The programs screwed it up.Try windows movie maker,not sure what it can do but it is windows own program for editing wmv files.
Extract ALL of the audio from the video files then clip the resulting audio files to desired length. good luck trying to get them to sync!
Her name is Laura. She loves my bush. -
If you want to extract portions form a WMV file use WMV splitter from boilsoft.
http://www.boilsoft.com/When I was born I was so shocked that I could'nt speak for 18 months.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Cutting HD files
By surfer in forum EditingReplies: 2Last Post: 23rd Jan 2010, 13:06 -
cutting FLV files
By shaema in forum EditingReplies: 2Last Post: 24th Sep 2009, 11:01 -
Cutting VOB files
By DELTAsnake in forum EditingReplies: 20Last Post: 6th Apr 2008, 16:23 -
automatically cutting a large wav file into x minute chunks?
By graysky in forum AudioReplies: 5Last Post: 22nd Sep 2007, 22:12
